Why Bypass The Tail Switch?
25 posts / 0 new
Yourrid
Yourrid's picture
I’m still trying to understand the theories behind a lot of what you longtime modders do, so I have a question; in what circumstances is it good to bypass the tail cap switch? I’ve only tried it once before on a BLF EE X6 triple that Nitro (patiently) helped me with, and am wondering if I should do it more often.
Is there a certain amperage that makes it beneficial?
Should it be done on all direct drive lights? (single and multi-emitters)
Is there a right and wrong side of the clicky to use to bypass? (if so, how do you tell)
I’m about to put together a Convoy S5 Triple and am wondering if I’ll have to do this again.
Thanks humoring the newbie Big Smile
Rufusbduck
Rufusbduck's picture
Last seen: 6 months 1 week ago
As far as I know the idea is to bypass or augment the current cap capacity of the tail cap spring. Bypass the switch and how do you control the modes?
Scott
Tom E
Tom E's picture
Last seen: 5 hours 32 min ago
I've never bypassed a switch, accept in a temporary test. Why would you do this? I've found cheap switches that have high resistance, but my first choice is to always replace the switch with a better quality one.
MRsDNF
MRsDNF's picture
I thought they were just bypassing the board by taking the battery contact part of the spring directly to the switch tab.
Halo...
Halo...'s picture
Last seen: 5 years 2 months ago
Yea, I suspect he means bypassing the springs and traces on the switch pcb. Not actually bypassing the switch itself.
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 2 years 11 months ago
My brightest direct drive SS-5039 10440 light is one that I made into a twisty. In many lights the switch is integral with the tail spring, or odd shaped, or small, and hard to replace with a lower resistance one. Also, for pocket lights, some length can be saved by cutting off the part that holds the switch. The most compact lights are all twisties.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
Yourrid
Yourrid's picture
Sorry for all the confusion guys; MRsDNF is spot on with what I’m trying to say.
FmC
FmC's picture
Last seen: 8 months 3 days ago
Check out djozz’ in-depth post regarding spring resistance.
When building any high-Amp capable builds, such as your triple, a spring bypass becomes necessary, both to get the expected performance, & to stop the spring its self from overheating & collapsing.
luminarium iaculator
luminarium iaculator's picture
Last seen: 16 hours 44 min ago
Or replace with beryllium copper springs and you don't have to bypass anything.
Yourrid
Yourrid's picture
I get bypassing the springs, I’m talking about drilling a hole through the PCB and running a wire directly from the spring to the switch.
FmC
FmC's picture
You are connecting directly to the switch tab, rather than relying on the via of the PCB and it’s traces.
Again, its about minimising resistance.
Tom E
Tom E's picture
Ahhh - ok. This mod , for me, came directly from Dale - he described it with pictures in great detail - where, I dunno, but I'm pretty sure it was on one of his triple or quad BLF EE A6's X6's. With the insane DD multi emitter single cell lights we build, there's a lot of amps going thru the tailcap, like 10A+. He said he had experiences where he smoked the trace on the PCB board the switch is mounted on, so the purpose of this bypass mod is to eliminate the use of the PCB trace that might burn up from the high amps.
 So it's not a mod that was done to lower resistance, but rather to save the trace from burning up. I think it's side effect though is lowering resistance by a very small amount. From my experiences, the weakest (highest resistance) part of a circuit will be the failure point, so for the EE X6 lights, most likely that trace is the weak point in the tail.
 I've done this mod on the two multi-LED EE X6 lights I built. I think I did it on a couple of other lights. It's very similar to the tailcap mods we do on the SupFire M6 or other SRK style lights where we bypass the PCB traces. I've done similar mods to the battery carriers in lights like the Shocker. Traces on PCB boards, specially long ones, can't compete with 22 or even 20 AWG wires.
nitro
nitro's picture
Last seen: 1 week 5 days ago
Tom E wrote:
Ahhh - ok. This mod , for me, came directly from Dale - he described it with pictures in great detail - where, I dunno, but I'm pretty sure it was on one of his triple or quad BLF EE A6's. With the insane DD multi emitter single cell lights we build, there's a lot of amps going thru the tailcap, like 10A+. He said he had experiences where he smoked the trace on the PCB board the switch is mounted on, so the purpose of this bypass mod is to eliminate the use of the PCB trace that might burn up from the high amps.
post #156 & 165
http://budgetlightforum.com/node/36881?page=3
Very nice indeed...
For lazy people video about how to is here
Picture is here.
Thanks to the author DBCstm
LazyJ
Last seen: 5 years 5 months ago
I once did this to bypass the ramping circuit in a tailcap… it made so much sense I do all my spring-bypassed tail switches like this.
Tom E
Tom E's picture
Oops - yes Nitro, that's it! In your heat sink thread Smile. Oops - I typed A6 but meant X6 - corrected above... Dale (DBStrm) mentioned this mod a few times, never knew exactly what he was doing til he posted the pics and video. I'm thinking it helps lower resistance on high amp mods a little, maybe more than I first eluded to.
Theodore41
Last seen: 1 month 4 days ago
Tom E wrote:
I’ve never bypassed a switch, accept in a temporary test. Why would you do this? I’ve found cheap switches that have high resistance, but my first choice is to always replace the switch with a better quality one.
Can you suggest one please,good for a BLF A6,a Nitecore P12GT and a Cometa?I don’t put in the row the SR52-UT and the K70,because I am afraid if I ruin them,as their price is high enough.
I am more interested especially for the Nitecore,because when I swapped the mirror of the A6 to a 20mm 15 Degree Cree XM-L LED Lens,the Nitecore gone away ashamed,so I want to give it a “viagra”. Wink
Tom E
Tom E's picture
Not sure I understand. By suggest one, do you mean a replacement switch? As far as I know, all the switch's in the lights you mention are better quality ones. I've only replaced cheap, poor performing switch's, typically more common in under $12 lights.
thijsco19
Last seen: 21 hours 40 min ago
Tom E wrote:
 So it’s not a mod that was done to lower resistance, but rather to save the trace from burning up. I think it’s side effect though is lowering resistance by a very small amount. From my experiences, the weakest (highest resistance) part of a circuit will be the failure point, so for the EE X6 lights, most likely that trace is the weak point in the tail.
It’s all about resistance.
That is one of the cons putting high amps through a circuit.
You know about ohms law right? V / I = R
More Amps, with a fixed resistance, equals more power (watt) turned in to heat.
So the trace (or spring) is rated for ‘x’ Amps, i.e. has ‘y’ ohms resistance, when you put more than ‘x’ Amps trough the trace it heats up because the resistance stays the same i.e. more power is turned in to heat. That’s way it burns up.
When we lower the resistance, using a bypass, more current can flow maintaining the same power lost OR lowering the power lost and maintaining the same current.
In flashlights both happens, because the current is somewhat controlled by the battery, led and driver.
A theoretical example:
Using a voltage supply of 4.2V, led voltage threshold of 3V and total resistance of 0.1 ohm
I=V/R, I = current, V = voltage, R = resistance.
  • 4.2V – 3V = 1.2V / 0.1 ohm = 12A.
    That means there flows 12A trough the curcuit.
    Power turned to heat in resistor is (P=VxI) 1.2V x 12 A = 14.4 W.
In this example we lower the resistor to 0.01 ohm
  • we get 1.2V / 0.01 ohm = 120A.
    Power turned in to heat in resistor is 1.2V x 120A = 144 W.
But the current is limited by a couple factors (voltage drop battery and voltage increase led)
So in this example we have a voltage supply of 3.8V and a led voltage threshold of 3.68V
  • 3.8V – 3.68V = 0.12V / 0.01 = 12A
    0.12V x 12A = 1.44W turned to heat in resistor.
Tom E
Tom E's picture
Hope this is not directed to me because lot of time wasted then. You realize the quoted piece of a post is from a year ago? I've been bypassing traces in mods for certainly over 2 years, maybe 3, and I've been criticized for doing too much of it. I thought I was one of the originals that did it, and still do it on a regular basis. Here's my 6 bypass's on a MtnE SRK driver, with 18 7135's added, and the bypass's gained about 2.5A:
And these are bypass's on the tail of the same SRK clone with a heavy gauge clamp meter loop build in:
Ouchyfoot
Ouchyfoot's picture
I agree with toms bypassing (beefing up) of traces. I followed his lead in bypassing all the traces in the battery carrier of my BTU shocker and gained a full 1A gain, which was pretty much the same gain Tom realized when he originally beefed up his Shocker traces. That’s confirmation enough for me.
thijsco19
Didn’t realize that, but it was not directly pointed to you. Though does sound like it.
Just some general info.
Theodore41
Tom E wrote:
Not sure I understand. By suggest one, do you mean a replacement switch? As far as I know, all the switch’s in the lights you mention are better quality ones. I’ve only replaced cheap, poor performing switch’s, typically more common in under $12 lights.
ΟΚ thanks.You see it is not enough time I am in the lights’ club.
Rufusbduck
Battery capacity is measured in amp hours but it’s the voltage supplied that generates the current. Eliminating resistance eliminates voltage drops so that it remains available to the led leading to higher current through the led at any given battery voltage.
Scott
Tom E,
A lot of effort in your work… Awesome Smile
