It's a 3x AA light host that should be fairly moddable. It's a bit thick and heavy for a AA light. I don't recall if the pill is solid or hollow, but IIRC, it can take standard 17mm drivers and 16mm PCB. I can measure the reflector if you like, for possible replacements.
Mine was not functional on receipt, but I bought it for host-duty anyway, so I kept it as-is. I still haven't built anything using it yet...
sort by date — it’s been a few weeks and so I can’t tell you what’s available now, but you can find them from time to time.
You can get creative searching if you want to spend the time sorting through an ’oogle-barf: https://www.google.com/search?q=flashlight+AND%223xAA%22+OR%223+AA%22-AAA&ie=utf-8&oe=utf-8#q=flashlight+AND%223xAA%22+OR%223+AA%22-AAA±xenon+AND+CNQG+OR+DX
Of course, searching here at BLF (search box, upper left corner) is endlessly fascinating, tho’ some of the sources are defunct (like Manafont, long gone)
RaceR`s 3xAA P60 host.
Modding the Lethargic Lanshi LS-125 3xAA
Hmmmm, I guess the 3AA “Police” might Lego/Frankenstein into a 4xAA light, if that 3xAA thread fits a SK68.
But no. I’ve got to stop somewhere.
Does anyone have a currently working link to a seller that has both the 2xAA “3W Police” and the SK58, or 68, or #3 zoomie, cheap, for Lego/Frankensteining?
The nicest looking Frankenstein’s Lego I’ve made takes the tube and switch from a 2xAA Police, added to a SK58 (with a decent emitter and driver swapped in)
— SK58 has better balance and fewer sharp edges than the SK68.
But I don’t know a good source for cheap SK58s.
OK. Got these in.
First the LED is an XRE EZ900 smallest XRE made.
Driver puts the current at 1.2A at tailcap from 3AA cells
Zoom to Flood is amazing
Unfortunately; The body is 22mm diameter and equally fat like my 18650’s flashlights. Bummer. Wish It was thin like my 2xAA MiniMags.
True: looking at this picture shows the tube wall to be much thicker than necessary. It's the same with the cheap eBay light I linked to previously as well.
