Just like the title says. I’m looking for this white thingy. The switch wouldn’t work without it. This current one is from a solarforce switch. Any site I can order this from? I don’t even know what it’s called…
I’m having some problems with my Flickr so you can juz click on the broken square as it’s a link to the photo
I can’t help with the spacer but with the picture…
I just click on the small arrow pointing down and select original size, than the picture opens in a window/tab. This link can normally embedded in the forum
A flat steel washer with the same inside diameter hole and same outside diameter of the plastic part will work fine as a replacement. All the plastic part does is locate the switch itself. The part in the following link will give you an idea what I'm talking about.
