This thing contains AA (14500) CR123A (16340) 18650, 18700 (for longer protected batteries) 26650 and multiples
Cool thing is the design there are slits on the ends, you take wire and wrap em thru the slits for the contacts to the batteries, the design itself has the spring made from the printing, combine this with some of those TP4056 modules and voila…instant really cool DIY homemade charger!
There is even one with them in series (for those guys with hobby chargers and balancing plugs [I guess a strip of copper soldered on the balancing lead slipped between the batteries for proper balancing])
and just as i thought of firing up solidworks and making a 18650 holder with a slot to hold a common tp4056 board.
i have been making “ghetto” chargers with cheap ebay 2 and 4 cell “blossom” holders with the cells parallel and the board glued to the bottom.
I’m going to be building my own charging setup soon using the cheap $2.50 spring loaded chargers on FT, but with the guts torn out and connected to a hobby charger.
if i get bored i will create what i set out to do.
a 4 cell with pockets to hold 4 4056 boards.
anyone know of strong CLEAR filament for 3d printing?
idea is to have the lights from the boards show in their corner of the box.
i also intend to build a support in to prevent the microusb port from getting busted.
