Test/Review of Energizer AA 2000mAh (Silver) (NH15-2000)
Official specifications:
  • Chemical System: Nickel-Metal Hydride (NiMH)
  • Designation: ANSI-1.2H2
  • Nominal Voltage: 1.2 Volts
  • Rated Capacity: 2000 mAh at 21°C (70°F)
  • Typical Weight: 30.0 grams (1.1 oz.)
  • Typical Volume: 8.3 cubic centimeters (0.5 cubic inch)
  • Terminals: Flat Contact
  • Jacket: Plastic
  • Temperature: Charge: 0°C to 40°C, Discharge: 0°C to 50°C, Storage: -20°C to 30°C
Maximum temperature raise at different discharge currents: 1A:+1,3°C, 2A:+3,5°C, 3A:+6,1°C, 5A:+12,1°C, 7A:+17,6°C, 10A:+21,8°C
Medium capacity NiMH from Energizer, there was no LSD specifications for the cell, i.e. they will have to be recharged before use.
I got the batteries with a charger.
The traces for the two cells tracks very fine and capacity at low load is about 2000mAh as specified
Conclusion
The cells has good performance, but I would get some LSD rated cell instead.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
A cell for people who still don’t know about eneloops. Thanks hkj :slight_smile:
What’s LSD rated?
This means that the cells will be years to discharge by itself, the above cell will probably discharge in a few months when not used (In bad cases it may get down to weeks).
Oh, that’s bad.
Thank you very much for the review!
I think LSD stands for low self discharge.
