Test/Review of CaroNite 18650 2800mAh (Purple)
Official specifications:
  • Brand: PALIGHT
  • Type: Lithium Ion
  • Model: 18650
  • Battery Capacity: 2800mah
  • Battery Voltage: 3.7V
  • Rechargeable: Yes
  • PCB Protected Board: Yes
  • Weight: 48g
This is a protected battery for application with a lower current drain.
The difference in tracking may be due to difference in the protection circuit, but there is a capacity difference between the cells. As can be seen the battery can only deliver 3A for a short time before the protection trips.
Conclusion
I am not very impressed with this cell, both the difference in capacity and the fairly low current limits can be problematic.
The capacity is also on the low side for 2800mAh batteries.
Notes and links
The batteries was supplied by tinywind.com for review.
Compare to 18650 and other batteries
“Top USA Technology” :bigsmile:
It’s not a good sign when Trustfire 3000 mAh Flames test better than these cells, at almost 1/3 the price.
