Test/Review of Lidu Dual USB Power Adapter / Travel Charger
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 days 13 hours ago
DSC_8957
Official specifications:
  • Color: White
  • Material: Plastic
  • Current Output: 2.3 A
  • Input Type: AC 110-240V
  • Output Type: DC 5V
  • Plug Type: Euro
I got this charger from fasttech
DSC_8955 DSC_8956
I got this charger in a retail plastic box.
DSC_8959 DSC_8960 DSC_8961
DSC_8962 DSC_8963
Measurements
  • Power consumption when unloaded 0.17 watt
  • USB output top is coded as Apple 1A
  • USB output bottom is coded as Samsung tablet.
Lidu%20Dual%20USB%20top%20load%20sweep
Lidu%20Dual%20USB%20bottom%20load%20sweep
Top and bottom output looks the same, i.e. they are in parallel. About 2.1A the output voltage will start to drop and at about 2.4A the over load protection kicks in. This is a good behaviour.
Lidu%20Dual%20USB%202.1A%20load%20test
Running a load test at 2.1A did not work, the charger shut down after 16 minutes. It is nice that it can shut down when over heated, but I would have liked to get the rated current from it.
Lidu%20Dual%20USB%201.8A%20load%20test
Reducing to 1.8A improved it a bit, now I could run for 43 miutes before it shuts down.
Lidu%20Dual%20USB%201.6A%20load%20test
At 1.6A it works perfectly
The temperature photos below are taken between 30 minutes and 60 minutes into the 1.6A one hour test.
Temp1668
M1: 44,9°C, M2: 35,7°C, M3: 43,1°C, HS1: 61,0°C
It is not that hot.
Temp1669
M1: 43,6°C, M2: 38,9°C, HS1: 53,1°C
Temp1670
M1: 45,9°C, HS1: 58,4°C
Temp1671
M1: 37,4°C, HS1: 42,8°C
Temp1673
M1: 32,6°C, HS1: 45,6°C
2.5ohm
The noise is fairly low at 2A with 82mV rms and 340mVpp.
10ohm
With lower load the noise decreases: 42mV rms and 260mVpp
Tear down
DSC_9175
Some pressure on the box and it pops open.
DSC_9176
This circuit has a real fuse, a bridge rectifier, a inductor (L1), but the Y capacitor (Y1) is not a approved model, it is a 1000 volt regular capacitor.
DSC_9177 DSC_9178
On the bottom of the circuit board is a switcher IC to control the charger, including heat shutdown.
The big rectangular device below the trafo is a diode and it looks like this is the major heat source.
The soldering do not look very good
DSC_9179 DSC_9180
DSC_9181 DSC_9182
DSC_9183
This charger has some isolation distance, but not enough.
The charger failed a isolation test with 2500 volt, this makes it doubtful to use with 120VAC mains, not the best situation for a charger with 230VAC plug.
Conclusion
The performance of this charger is acceptable, but the safety is not.
Stay away from this one!
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
Ormbett
Ormbett's picture
Thanks for the review, and the skull 8)
MountainKing
Last seen: 1 month 1 week ago
Lol Smile The performance is acceptable _
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
akhyar
akhyar's picture
Last seen: 1 week 2 days ago
Thanks for the review and warning HKJ
