Hello,
I decided to buy a Palight BOSS1 and review it here. I purchased it from Gearbest on January 20th, 2016. I decided to show the shipping time in the review thread as well as the review itself.
The package was picked up on the 21st of January 2106 and it was supposedly sent to an airport on the 22nd of January 2016. That is all the information I have so far. Here is a photo of the info from this International Bridge company, which Gearbest is calling "America Line". Supposedly 3-7 days shipping, but it is going to take longer than that.
Here you can see the "IB" number as well as the USPS number below it, on the left side.
IB4533828308915
USPS # 9205 5901 0007 5372 6436 06
USPS also shows the package departed the shipping partner facility on the 22nd.
From what I can see, the package went from the green dot, to the purple dot and then it went to an airport, but which one? I do not know. I would think Hong Kong, but I just do not know.
Unfortunately, this does not show if the package ever got on a plane yet. It is supposed to go to the CVG airport in the USA, which is the Cincinnati/Northern Kentucky airport.
So, as of now, location unknown, just as any other international shipment and time to receive unknown as well.
I think knowing how this international shipping works or does not work, is important in a review. I wish I had done this more often, since time to arrival is a big deal for a lot of people.
I will let you know more, when I know more.
01/28-16 I contacted International Bridge about the lack of tracking after leaving China. I got a response in a few hours.
"Our internal tracking shows that we were notified to expect a package on 1/21 but didn't actually receive the physical package till 1/22. The shipment containing your package arrived in the US on 1/25 and is still waiting to clear customs, because of it being an International shipment. Normally custom clearance happens the same day it arrives, but sometimes it could take up to even a couple days for deeper inspections. Unfortunately, I can't provide you an exact ETA at this time until it actually clears customs. Once released, our tracking will be updated accordingly and we will hand it over to USPS for the final delivery to your home, in 2-3 days, with your regular mail."
So, the package made it to the USA in 5 days, but it is now held up in USA Customs. I have seen packages sit in USA customs for 3+ weeks and I have seen packages disappear there too, with never a trace. I hope the customs in CVG airport gets it inspected soon.
At this point, I have to say Gearbest and IB did what they said and got the package to the US, so I can't complain at all with their timing. Looks like Customs and USPS will be the holdup here. Maybe a lot of packages do not clear customs easily. Might be why we think they never get out of China, because there isn't good tracking or any, when they come into the US.
2016-01-31 19:01:46 | Alert: Package was cleared by Customs 1/28 but not released in time to pick up Fri. evening. We will retrieve shipments Monday and induct to USPS. Please check your USPS track # for update on USPS.com by Monday pm or Tues. am latest for most accurate ETA. |
Well, IB seems to at least keep things updated well. Looks like I should get the package by Friday of next week, so basically no different from any other shipper except DHL. Looks like about 15 days total.
02/03/16 - So, USPS has the package finally and it will be delivered on the 5th, as I suspected, so 15 days for fast shipping, that ended up being the same or worse than economy shipping, but only because of USA customs. I wrote customs and asked how long it took to pass a package and they said their maximum, before doing any checking, was 45 days to pass customs. 45 days folks, before they would start a search. How wonderful to know.
Anyhow, I will not review it till the 10th or 11th of February, so by then it will be closer to a month. Sort of a pain in the arse and one of the many reasons I had given up doing anything with Chinese lights. It's just too much of a pain to deal with.
02/0416 The light came today!
Palight Boss1 4x26650, XM-L2 Spotlight/Flashlight - purchased for $54.83 USD, from Gearbest.
http://www.youtube.com/embed/MIMpneAMB3Q
I have a video as well as photos this time, in case some cannot see the video.
- OAL 175mm
- Head OD 100mm
- Reflector OD at large end 89.8mm
- Reflector Height 57.9mm
- Reflector LED hole diameter 9mm
- Lens OD 89.7mm and thickness 2mm
- Driver OD 67.38mm
- Modes are L/M/H/Dual strobe - NO mode memory. Always starts on low mode!
- Amps are .45amp on low, 1.16amps on medium, 1.88amps on high. With One MNKE 26650
Also read Tom E's post on this light. He got very different readings than I did, so it's good to look at all the info you can get.
From Tom E - I documented my results in post #138 here: https://budgetlightforum.com/t/-/36643
and here, in this thread https://budgetlightforum.com/t/-/37800#comment-892834
Packaged in an outer plastic sack.
Then a box and...
another box inside that, with the light in bubble wrap.
First thing I thought was how heavy it was.
Second thought was how ugly the handle was, with the rubber cover pushed over top of the steel handle.
The lens is coated glass, but not AR coated, just plain green glass coated. I call it green glass, but it is pretty much the standard glass used on most everything.
The big reflector looks good. No blemishes to be seem.
Tail cap - did I say the handle looks ugly?
2# 6.4oz without batteries, or 1100 Grams.
3# 3oz or 1450 Grams with four 26650 cells.
Driver plate
Inside body
Tail switch on the back plate.
4x26650 or 5x18650, if you used 4 sleeves on the outer 18650 cells, then a 5th could be added.
Very few threads on the body, especially on the body to head end.
Other side of the driver.
LUX @ 2 meters. It settled at 33,600. The meter is set for x100, so 33,600 LUX @ 2 Meters. One of you guys can figure out the kcd from that right? My mind can never get around that stuff.
Beam from around 12 feet on high. Camera shows a larger hotspot than my eyes do. By my eyes, the center spot is about 15" in diameter.
I am jaded. I have seen so many lights over the years, that it takes a lot to impress. I am not impressed. The machining is good. The Anodizing is good. The threads are average and not lubed. The amp draw on high is Way too Low. Only about corrected 9+mm space between driver and led shelf, which leaves a little space for modding a thicker heat sink. Not enough threads on the body to head threads. Driver with positive contact points instead of a contact ring, causes possible alignment problems when screwing the body on, with cells. Mine was misaligned upon getting it. Plain coated glass lens.
It is an ok light and for the average non-flashaholic, it will probably be fine, but for us, it just does not cut the $50 price range. It needs to be more around $35 or $40, unless you feel the 4x26650 is something to rave about. Modern 18650 cells match amps with most 26650 cells anyhow, so the 26650 novelty doesn't warrant the price hike. The beam is not as tight as I had hoped for, nor is the output anywhere near what I had hoped for. It should be hitting at least 3 amps and more like 3.5 to 4 amps. instead of the measly 1.88 amps it does on high. It might be good for a mod to XP-G2 dedomed or something, to get a more intense spot. As is, it is just an average spotlight at an above average price.
More tear down photos.
LED shelf just sits in the bottom section of the head.
Other thoughts
