Test/Review of AW IMR18490 1200mAh (Red)
Official specifications:
  • 1200 mAh
  • Voltage: 3.7V
  • Peak Voltage: 4.2V
  • Dimensions: 18D x 49H mm (+/- 0.5mm)
High current 18490 (Same as 18500) from AW, the 15C means 15*1200mA -> 18A, as can be seen below it is probably a bit to high.
The cells are not maches perfectly for capacity, but acceptable. The 10A trace looks fine, 15A is a rather high load for the cell and 20A is too high.
Conclusion
The cells has fairly good performance, but compared to other 18490/18500 cells it is nothing special.
Notes and links
Compare to 18650 and other batteries
