Test/Review of power bank Tech Armor ActivePower 3000
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 11 hours ago
Power bank Tech Armor ActivePower 3000
DSC_3154
This is the smallest power bank from Tech Armor.
Official specifications:
  • Battery type: Li-ion
  • Capacity: 3000mAh/77Wh Wh specification is not correct
  • Input: Micro-USB 5V/500mA
  • Output: USB 5V/1.0A
  • Dimension: 55mm x 9mm x 8mm These dimensions are from the manual, but are not correct
  • Weight: 65.2g + 10g
How does it look
DSC_3147 DSC_3148
The power bank is delivered in a cardboard box with a list of all models on the backside.
DSC_3151
It contains the power bank, a usb cable and a "instruction sheet".
DSC_3157 DSC_3158
All connectors and one indicator is placed at one end
  • Micro usb: Charge input.
  • 1A usb output.
  • Small hole for led: Red:charge, Blue:full (The led can also been see in the usb output).
DSC_3155
DSC_3156
Measurements
  • Device can work as ups.
  • Input current is not directly affected by output current.
  • Red light while charging
  • Blue light when full.
  • USB output is coded as usb charger (DCP).
  • Size: length: 90mm diameter: 27mm
  • Weight: 70g (Accessories not included)
Tech%20Armor%20ActivePower3000%20load%20sweep
Output starts to drop at 1.2A and is turned off at 1.7A.
Tech%20Armor%20ActivePower3000%20charge%20load%20sweep
Doing the same sweep with charge current connected, this time it could keep the output stable up to 1.4A and it did not turn off even at 2A load.
The charge input current was not directly affected by the load current, but it would ramp up to full charge current. It looks like the circuit is missing an overload protection, but when run on battery alone it will turn off due to voltage drop on the battery.
Tech%20Armor%20ActivePower3000%20usb%20out%2010ohm
The power bank can supply nearly 2000mAh at 5 volt, this is a very good value for a 3000mAh power bank (mAh rating is based on battery, see capacity table).
Tech%20Armor%20ActivePower3000%20usb%20out%205ohm
Increasing the load will reduce the available mAh a bit. The boost converter cannot keep the voltage up during the full discharge, but stays within acceptable tolerances until the power bank is just about empty.
10ohm
The noise is fairly low with 0.5A load at 24mV rms and 190mVpp.
5ohm
But increases a bit at 1A load: 50mV rms and 320mVpp.
The charge starts slowly and increase to 1A current nearly immediately. I had to charge 3000mAh, i.e. the cell inside is about 3000mAh.
Tech%20Armor%20ActivePower3000%200.5ohm%20charge
Adding a series resistor to the 5 volt charge supply will reduce the current, this makes it slower to charge, but it is charged just as fine as above.
Conclusion
I like the rounded triangular shape of the power bank and it works well.
I will call it a good power bank.
Notes
The power bank was supplied by Tech Armor for a review.
Read more about how I test USB power supplies and chargers
Martini
Martini's picture
It does look like a good shape.
scdaf wrote:
It’s important to have your restraints within walking distance, lest someone needs restraining. Wink
