Test/Review of Imren IMR18650 3000mAh (Purple)
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 20 hours ago
40A%203000mah%281%29
Official specifications:
  • Model: 18650
  • Capacity: 2500mAh
  • Nominal voltage: 3.7V
  • Weight: 50g
  • Length :65.11mm
  • Diameter: 18.19mm
  • Material: Li-Mn
  • Max. Discharge rate: 40A
  • Continuous Discharge rate:32A
Imren%20IMR18650%203000mAh%20(Purple)-info
A high current and high capacity cell from Imren.
DSC_1990
40A%203000mah%20%282%29 40A%203000mah%20%283%29
40A%203000mah%20%284%29
40A%203000mah%20%285%29
40A%203000mah%20%286%29
Imren%20IMR18650%203000mAh%20(Purple)-Capacity
The curves looks very good up to 15A, one cell do also have a good 20A curve.
At 30A the cell has trouble and needs to heat up, before it can deliver the current, the output voltage is also rather low.
The white and yellow line may be a problem with my test station (bad connection).
Imren%20IMR18650%203000mAh%20(Purple)-CapacityTimeHours
Imren%20IMR18650%203000mAh%20(Purple)-Energy
Imren%20IMR18650%203000mAh%20(Purple)-PowerLoadTime
Imren%20IMR18650%203000mAh%20(Purple)-TripCurrent
Imren%20IMR18650%203000mAh%20(Purple)-Charge
Conclusion
These cells has good performance up to 15A and can handle 20A.
Notes and links
The battery was supplied by Imren for a review.
Because Imren changed the wrapper after they shipped the batteries to me, the above pictures are taken by Imren.
Compare to 18650 and other batteries
Wrathbringer27
Wrathbringer27's picture
Last seen: 2 days 13 hours ago
Thanks for the review HKJ. I have to ask. Do you get paid to do reviews? It’s okai if you don’t wanna answer if it’s a personap question. I’m juz really curious Silly
Words can be broken,
so can bones.
HKJ
HKJ's picture
Wrathbringer27 wrote:
I have to ask. Do you get paid to do reviews? It's okai if you don't wanna answer if it's a personap question. I'm juz really curious :p
No, except I keep the products (And sometimes I buy the products myself).
Wrathbringer27
Ahh thank you! Smile Thanks for fulfilling my curiosity! Hehe
so can bones.
JaredM
JaredM's picture
Last seen: 2 hours 16 min ago
Was this test done on your new equipment with 4 point measurements?
I’m wondering why there is noise in the 20A and 30A traces?
https://fundrazr.com/osturaband
No affiliation, just a fan.
HKJ
HKJ's picture
JaredM wrote:
Was this test done on your new equipment with 4 point measurements? I'm wondering why there is noise in the 20A and 30A traces?
No, I do still have a couple of cells done before the upgrade. If the review is missing the temperature charts, it is from the old setup.
JaredM
JaredM's picture
Okay. Thanks for the clarification. I was going to be surprised if the new setup gave these results. Great work as always. I don’t know what I’ll do when you no longer put out these awesome reviews. I check your site at least once a day. Greatest part is you never know what’s next..
