Varta AA 2100mAh (Green)
Official specifications:
VARTA Type: 56706
Reference IEC: HR6
Battery Size: AA
Height: 50.5 mm
Weight: 29.0 gr
Electrochemical System: Nickel-metal Hydride (NI/MH SINT)
Capacity: 2100 mAh
Retain 80% capacity after one year.
Voltage: 1.2 V
Maximum temperature raise at different discharge currents: 1A:+1,5°C, 2A:+3,6°C, 3A:+6,0°C, 5A:+10,9°C, 7A:+15,3°C, 10A:+18,6°C
Varta has many types of NiMH, these are LSD (Low Self Discharge) with moderate capacity.
I got the batteries with a charger.
Discharge curves look fine.
Conclusion
Generally they have a bit more capacity than 2000mAh cells, with a similar performance.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
