i read about solder alloys a few times…
the OLD stuff was better, as in easier to master soldering electronics. I WANNA remember 60/40 was the old fashioned standby mix, and MAYBE i wanna remember 64/37 as the “perfect” stuff ?? from memory without going looking… i hate the new stuff.
theres 2 temperatures that matter when soldering…
1) “solidus” - the temperature BELOW which the solder is solidified.
2) “Liquidus” - the temperature ABOVE which the solder is liquified.
when you got the old lead based solder? with the “perfect” mix? (maybe that was 63/37, i dont remember…) the solidus temperature AND the liquidus temperature? were the SAME TEMPERATURE. Basically there was one “magic temperature” aove which the solder melted, below which it was solid.
this made soldering easy… unless you ran your iron too hot, or, held the iron way too long? when you retracted your soldering iron, the solder joint almost instantly solidified.
when you move away from the “perfect” mix, or… the “new stuff” RoHS crap… the solidus and liquidus are two different temperatures.
the liquidis is a little or a lot higher temperature from the solidus… meaning? you heat it up… it flows… you retract your soldering iron? and you W-A-I-T for it to cool down to solid.
i tend to get “balls” of solder that “ride” instead of flow and puddle… i guess i need to buy a flux pen to get puddles and flow.
my advice? just DO IT… you soon learn to get SOMEthing working, and if youre like me? it will be UGLY and take forever… but “works”.
you get better at it over time, its an acquired skill.
just resist the temptation to melt the solder, instead concentrate on heating up the PIECE, and letting the solder melt when the piece is hot enoug to do it for you.
i like to keep some fine abrasive paper handy, and will “sharpen” my pointed soldering iron tip before using… then i like to “tin” the soldering tip… put some solder on it to cover it, and let it cook and flood the tip over.
then it works better. “tinning” the two pieces you are going to join first? makes them join more easily. I will tin the WIRE, then tin the “pad” by puddling solder there and cooking the puddle… then heat up the wire touching the cooled pad until it cooks together and retract.
shrugs easier to SHOW someone, it loses something talking about it.
PS - i am no expert… my soldering is a “hot mess”, pun intended… but it WORKS, if its a little bit ugly.
