Hi friends, needed O-ring for this light, store for huy?, thanks.
Can’t help you with the oring, but if you can’t find any you can wrap plumbing tape around the threads and it works pretty well.
There is a spare o-ring supplied with the flashlight, did you check for it?
Yea mine came with a spare o-ring or else just grease up and it will be okay for now…
Fasttech has small o-rings:
Rubber o-ring for e-cigarettes
from 10 to 5 mm total diameter and 1 mm of thickness.
But you need, if possible, less than 1 mm Tickness. I only know this german e-bay store:
Hi alejandrov, we are both in Spain, why we aren`t speaking in spanish? regards,
Mine did not come with any o-ring :(, now the thread goes a little loose, almost I lose today
https://www.fasttech.com/products/0/10006772/1886600-silicone-o-ring-seals-for-atomizers-50-pack
Estas funcionaran?, es que las de la Spy por el grosor se queda pillada…
Because this is international forum and we use international language so everyone could understand everyone…
If you want thousands and thousands people to understand (and help) you use english
if you want 10 peopel to understand you can use spanish or chinese or hungarian language…
Yesyesyes, sorry, I knew thats was not right, it was a boost, hope not repeat :innocent:
Regarding o-rings, my experience with small DQG’s is that 1mm tickness o-rings end broken sooner than lather; so I have just ordered a set of 5 x4 x 0,5 mm and another set of 8,3 x 6,7 x 0,8 mm o-rings, I will post the outcome when I receive them.
