While I am waiting for my flashlights to come in, I was cleaning out the old electronics bin and pulled out two Dell Type 75UYF battery packs. I've read that some BLF'ers recycle batteries from inside laptop packs, so I decided to open one up.
I carefully pried the pack apart to unveil an 8-cell cluster. I was expecting to easily read the battery type right off the cell but none of the numbers matched up. I tried to Google the pack model number and any of the numbers off the cell itself but could not find anything. I was hoping that one of the BLF battery gods could help me identify what I have. I was hoping to recover some 18650's.
Being new to lights and batteries I didn't want to assume that they were 18650's. Comparing them to the pics on the web, they look like they are Sanyo Red 18650's.
Per instructions here on BLF, I separated the cells and took off the thin metal straps located on the positive and negative ends of the battery. However, it looked like they were "stapled" onto the ends. Now the leads have remnants of "staples" on them. How should I "knock down" those pointy ends or should I just leave them?
Thanks again kbark for the heads up. Here are the eight batteries from the first battery pack all cleaned up. I used a dremel to knock down the "staples"
look the same as the ones I got out of an old IBM notebook.
(they are clearly a fair bit smaller than my 18650 Flames.. )
They were all about 4.1x Volt after charging them in the laptop.
This I could check of course after I opened the battery pack!
Recharged them on my TR001 charger.. then they had all between 4.15-4.18V
when that laptop still worked, it could work on the battery for about 10 minutes.....
(now maybe thinking about putting the batteries in my other old laptop, that has only 3 cells, which are probably dead.. no charge at all)
I just got in my 4Sevens Quark 123^2 and fighting the urge to charge and put in one of these 18650's I pulled from my Dell pack. Should I really wait for a multimeter to test the batteries BEFORE putting them in or do you think the Quark is robust enough to give it a try?
Well, these cells are actually used. At the end of their life cycle, sometimes a cell may be in better condition than others. If you use them in a 2S or 3S configuration, problems may arise especially without PCB protection.
Other unprotected cells that you buy elsewhere are new.
DOH! In my excitement about recovering these 18650's I realized that I misspoke about about the 18650's going into the Quark X 1232 (thanks mitro for pointing it out). What I'll be looking at for my new Quark will be the 17670.
I opened the other Dell battery pack and pulled out 8 Sony Greens. Now I'm on the search for a single 18650 setup. Anyone got suggestions? I heard the Solarforce L2i is a relatively good form factor to build on.
Check them with a meter before attempting to charge them ..obviously the pack is bad for a reason ..Right ? something in there is bad or it wouldn't be an old laptop bad battery pack . You need to know which cells are bad and toss those ..i keep only batteries that aren't discharged lower than 3 volts ..i charge them as high as they will go.. 4.2 volts .. and then check voltage again and write it on the cell and date it .. Then let it sit for about 3 days or so checking voltages once a day .. if a cell won't even charge up to 4.2 volts that's not a good sign and any cell that starts to freefall just by sitting is talking to you .. you need to listen if it drops to under 4.volts by its self it's bad .. tape it up and recycle it Imho this is the minimum safeguards to be taken with regards to l-ion cells
Be safe rather than sorry ... obviously if they get hot while charging at all they are bad .. pull the plug asap
Thanks for the heads up. The packs in question weren't bad. The laptop that went with them went bad. That's not to say the batteries aren't bad until I test them.
I ordered the Equus 3320 DMM from Walmart to go with the Ultrafire WF-139 I got in. Thanks for the great advice.
Discharging them in series with balance leads connected is a good way to see if any cells lag behind and if they will be good for multi cell use, but you need a hobby charger.
Great info Boaz! Woukd you mind starting a general purpose 18650 info thread with this info and anything else you could share? We could all benefit fro. Your knowledge. Thanks.
