Worklight comparison: 400W LED vs 500Wx2 Halogen
37 posts / 0 new
leaftye
Last seen: 1 week 2 days ago
400W LED flood light
Price: $98.44
Warm white tint, 44000 claimed lumens
Link : This is the actual one I bought
2× 500W halogen work light
Price: ~$50 a couple of years ago
16000 claimed lumens
Link : This isn’t an exact match for the one I have, but appears very similar.
This was a quick comparison, as shown by the aiming of the lights and camera, but I did use the same settings on my camera, which iirc were, .25 sec exposure, 1600 ISO, f2.8. Visually, both lights had the same amount of lighting, but the 400W LED pictures show more details in the background houses.
I’m sure this 400W LED flood light doesn’t actually draw 400W, and that’s something I plan on testing later this week. I took it apart and found 4 individual 100W drivers glued down, the LED’s glued and screwed down, and no grounding. The power cord uses thin 20awg wires, and comes without a plug. I’m debating on whether or not to mod this. Upgraded components will probably cost as much as two more lights, but these lights are huge.
Without a doubt I’ll be going LED instead of halogen from now on. Even though the halogen might offer a better lux/dollar value, it uses so much power that I can’t risk using any power tools on the same circuit.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
Edited by: leaftye on 10/25/2016 - 01:50
dchomak
Last seen: 2 years 5 months ago
The listing for the LED work light has been removed?
leaftye
Fixed it.
DavidEF
DavidEF's picture
Last seen: 2 days 9 hours ago
I don’t know about Lux/dollar, but for the Lumen/dollar value, if you go by the claims you posted above, the LED beats the halogen handily. Does it have actual electronic drivers? I had a couple 30w worklights that look like those (but with a single emitter), and they just used a transformer and a diode! I replaced the LEDs in both of them with MT-G2 and there was a huge difference in output and a lot better tint, too! They were to be used as worktop/task lighting, so I cut some paper to the size of the lens and put in them as a diffuser. DC-Fix would have been better, but I didn’t have any. Even with the loss through the paper, the output was noticeably more than with the stock COB emitter!
- The YKK Philosophy
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 2 hours 15 min ago
I have a 500 Watt halogen work light it does about 9000 lumen. I hate having to wait for the lamp to cool before i can move it!
An equivalent LED should be about 100 watts and do around the same 9000-10000 lumen!
DavidEF
DavidEF's picture
Yeah, according to the specs leaftye posted above, the 400w LED light is rated for 44,000 lumens, or 11,000 per emitter. But, that remains to be seen. We don’t know the quality of the light, the drivers, or the emitters in particular. It isn’t hard to believe it blows away the 2× 500w halogen, though.
Barkuti
Barkuti's picture
Last seen: 48 min 56 sec ago
Pretty sure the halogens' light quality (CRI) blows away those crappy leds.
leaftye wrote:
… The power cord uses thin 20awg wires…
20AWG thin wire? So what? You're transmitting AC mains, so no need for high currents, so no meaningful losses at that power rating. Wanna me do the math?
Wanna do a nice mod? Get some Yuji high CRI leds.
Cheers Party
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
leaftye
I don’t believe that rating for a second. It’s exaggerated even by chinese standards. The chinese 100W warm white LED’s are only rated for about 9000 lumens, so I don’t know where they’re getting another 2000 lumens from. The 100W led driver is fully enclosed like the waterproof led drivers you can find on ebay. It might even be this driver. The problem is that these drivers usually only seem to draw about half their rated current, so that’s going to drop output further. It didn’t blow away the halogen light in terms of perceived output, but it blows it away in terms of heat and should do it for power consumption too. I’m waiting on a line splitter to test total output, and if I thought about it earlier, I could have use my clamp ammeter to check when I had the back open. I don’t plan on opening the back again until I’m ready to replace the power cord. 20awg may be good enough if it’s only using 200 watts, but if for no other reason, I want it to have a thicker cord to match the plug I installed.
There are definitely other 100w LED’s with greater output and better CRI, but I believe those are $30. So that’s already $120. I think quality drivers cost about the same. I’m not doing all that. Mods will be limited to thicker wiring, trying to mod the driver, and maybe even running two drivers in parallel for each emitter if those things are as bad as some have found.
As far as quality, I doubt it’s waterproof if only because the port for the power cord was sloppily sealed with hot glue. The bezel and rear cover had a thick continuous strip of something that looked like silicone though. The paint isn’t great either.
If you guys get one, look up the color codes for EU wiring standards.
Lithopsian
Last seen: 4 years 1 month ago
Standard practice to quote the maximum LED rating and then install it in a circuit that runs at much lower power. Hard to say how much lower, but I wouldn’t be surprised at a half or even a quarter of what they claim. If it actually was drawing 400W, even allowing for the fact that the post is four years old, it would literally be a night and day difference to the halogens.
20 gauge wire is a safety risk in this situation regardless of the current being passed. This seems to be increasingly common on low power lights rated for small low energy bulbs like 14W or maybe 20W, but quite surprising to see it on a (supposed) 400W worklight.
DavidEF
DavidEF's picture
Why is 20ga wire a safety hazard? If it’s like the lights I had, the cable is heavy duty rated, and 20ga should be plenty for ~3.33A @120V to make 400 watts! I don’t see a problem.
I don’t have any issue believing they are running those emitters at or near the rated 100W each, but I’ve been wrong before. What I have trouble believing is the claim of over 100 lm/w from cheap Chinese COB emitters. I’d be more likely to believe ~60 lm/w efficiency. That would give ~24,000 lumens, which would agree with leaftye’s assessment that they don’t really blow away the halogens, but are marginally better. There are some better COBs, even Chinese ones, that really do 100 lm/w for just a little higher price. I can’t remember who, but I remember somebody did a review of one.
As for the wire color standard. I’m not sure there is one in China where these are made. If anybody knows otherwise, I’m interested in hearing it as well. It seems to me they just do whatever arbitrary color scheme that feels right at the time. But, really, you can test it out with a multimeter pretty easily, so it shouldn’t be an issue.
Lithopsian
As I explained on another thread, non-isolated mains-voltage lighting should use 18 gauge wiring. This has little to do with current-carrying capacity and much to do with the breaker or fuse blowing in the event of a fault before the flimsy wiring melts and sets fire to your ceiling or turns the light fitting live.
Most LED COM or SMD emitters typically run at near 100 lm/W. Anything remotely modern should be operating above 100 lm/W. How close you get to that in practice depends on the driver circuit. Expect to lose at least 10-20% converting mains AC to whatever DC your LEDs need, but 40% isn’t unusual.
DavidEF
DavidEF's picture
If you’re depending on the fixture wire to trip the circuit breaker, you better not stop at 18ga wire, but go ahead and make it at least 16ga or larger! Shocked
leaftye
I was going to use the thermal camera at the shop tonight to get some images to show how this thing heats up, but it has been moved to another shop where it looks like it’ll be staying indefinitely. That’s excuse enough to buy a FLIR One. I’ll get some thermal video next week.
SawMaster
Last seen: 1 year 1 month ago
My LED worklight situation is limited ATM, but I’m done with halogens at work. No more accidental burns, no more blown bulbs, no more eggshell-delicate handling when hot, and LED can be cordless. For a plug-in worklight I’m using an old-fashioned drop-light with an LED bulb- it’s all the light I need. I’ll use the old halogens for recreational area lighting where their drawbacks are not much concern.
Phil
leaftye
Measured 1.21 amps at 125 volts. That converts to 150 watts, which goes a long way towards explaining why the output doesn’t seem anywhere near its claims and doesn’t get hot at all. It’s pretty crazy to think that I could run 15-16 of these from a single outlet where before I could only run a single 500Wx2 halogen light.
DavidEF
DavidEF's picture
Just over a third of its rating? That is crazy! Shocked
So… what kind of mod are you going to do to it, now that you know that it’s so under-driven? Driver upgrade only?
leaftye
I’ll try finding equally bad, but super inexpensive, drivers to run in parallel to double current. Maybe at some point in the future I’ll get extra emitters and optics, then go back to one driver per emitter. It’ll still use 300 watts, but should be slightly more efficient, plus I can mix tints to get closer to 5000k.
How bright do you think the LED light is now? 10000 lumen? Why not just keep the driver and buy a few COB LEDs? Buy two 100 watt COBs? Should be good for about 16000 lumen! Almost as much as the halogen and less then half the power?
leaftye
Probably 20 thousand lumens. I’m open to ideas as long as they don’t cost much, otherwise I’ll get a second light. I may but those leds when I but the drivers since it doesn’t cost much more, but that mod would require optics, and I might have to machine a spacer.
I think COBs do not need optics it will just be super floody using the current reflector you have?
To me your pic of the halogen looks a lot brighter.
DavidEF
DavidEF's picture
So, buying a better driver, so that you can run one 100w driver per emitter, is not up for consideration? Connecting multiple drivers to each LED may be a problem for the electronics. If you want to go cheap, buy transformers and rectifiers! Big Smile
leaftye
The halogen certainly has a more intense hotshot. at least one of the lights were slightly pointing upwards, where the led was pointing up by roughly 10 degrees from horizontal. This is the design I’ll go for if I add emitters.
http://www.ebay.com/itm/272385350497
I think texaspyro has some threads about using those reflectors in his projects.
Wow that pricing lol! Can you tell what brand the current LEDs are in the light? Any model numbers?
I wonder if you could fit 4 of these in? You would have to lower the voltage but the amperage is correct.
https://www.fasttech.com/products/0/10013316/2250000-cree-cxa2530-60w-40...
leaftye
I’ll have to open it up again,but I’m sure it’s not cree. I don’t think those cxa emitter make sense for this light, but I may use them in an insane flashlight project. There’s plenty of room. When I get the FLIR, I’ll add a picture with both lights so you can see how huge it is.
DavidEF
DavidEF's picture
You could always try one of these.
leaftye
Not sure that would fit unless I used that to drive everything, but then there’s no room for additional drivers if this also fails to meet its rating. There are two compartments instead of one.
I’d like to see if the drivers in my light can be modded.
Barkuti
Barkuti's picture
Cree CXA2530 60W 4000K 6000LM COB LED Array Emitter
Real Cree stuff, specs you can rely on. Steve
Possible AC drivers:
http://www.ebay.com/itm/5pcs-Constant-Current-Driver-10-18pcs-3W-High-Power-LED-AC85-265V-40w-600mA-/231676178451
http://www.ebay.com/itm/Constant-Current-Driver-10-18pcs-3W-High-Power-LED-AC85-265V-40w-600mA-/221873496465
Two per COB emitter should do nice without being overbearing (≈1,2A). Of course, there may be cheaper options.
Cheers Party
leaftye
Brown Santa dropped off a FLIR One today. Here’s the video of a moment after startup to about 4 minutes. I like that it hardly gets warm. I recorded 43°C/109°F behind the center emitters, 35°C/95°F at the bezel. My wild guess at the room temperature is 18°C/65°F.
I thought perhaps the sensor was saturated, so I passed my hand through the video a couple of times to compare against body temperature. I suspect the shelf under the emitters is thin, which is why they are so easy to see. If I mod this to a 8× 100W light, I’ll have a thick plate of aluminum between the emitters and the shelf, and I can’t wait to see what that thermal image looks like.
Pro tip: Some platforms allow Youtube videos to be sped up 2x.
Terry White
Terry White's picture
Last seen: 2 years 6 months ago
I’m gonna follow the progress on this. We have this problem a lot at work. All but handheld work lights are still halogen power suckers with too much heat in some of the spaces we have to work in. And I already have guys asking about mods for their handheld led’s. Once they get me one new still in the box I will begin looking into it.
Great thread.
Terry White
Skype terrywhite1@live.com
Barkuti
Barkuti's picture
leaftye wrote:
… I recorded 43°C/109°F behind the center emitters, 35°C/95°F at the bezel. My wild guess at the room temperature is 18°C/65°F.
Let's see:
You said around 150W at the input. If, let's say, 5/6 of that power is dissipated in that heatsink through the emitters, peak heatsink °C/W = 25/125 = 0,2°/W.
leaftye wrote:
… If I mod this to a 8x 100W light, I'll have a thick plate of aluminum between the emitters and the shelf, and I can't wait to see what that thermal image looks like.
800W plus 0,2°/W means 160° above ambient. Great news! It'll look close to an electric heater, before the emitters blow up. Smile
Cheers Party
leaftye
That was just behind the emitter. Heat quickly dropped off away from the emitter. Since emitters would be spaced out, it wouldn’t be that bad. Upping the current is what would really pile on the heat since LED’s get less efficient as current goes up.
Current to each emitter would stay the same though. I’m talking about 800W worth of over rated chinese drivers, so it’d only double what’s already in the light, so really 300W. There’s room to cram 8 drivers in, but 16 would be pushing it, and that would still only get 600 watts. With 300W, it won’t get that much hotter, and might even run cooler if my big spacer distributes heat to the fins much more evenly. Drivers to get an honest 800W, much less Cree COB’s, are way beyond my budget for this light. They would be awesome to use, but it’s not happening right now unless someone else is paying for it. Wink
First mod will be doubling the drivers to each emitter for 66W each, then later I’ll double the emitters and come back down to 33W each. The latter mod should run cooler and produce more light than the first.
