I have, for a long time, wanted a very weak light source, dimmable to almost nothing. An idle day and I decided to refresh my very old knowledge about circuits.The link above is the result so far.
This circuit has not been assembled and may be wrong so be careful. If anyone can point mistakes from the simulation, thanks in advance.
The led drivers available at DX, KD and company are designed to be powerful and efficient, this one is designed to be simple and dimmable. Hence, efficiency is low - if you take a careful look you will realize that there is a lot more power going to the resistor than to the LEDs - but it should be very easy to build. And I expect it to provide a nice, noise free (no voltage converter) low power night light, blinking at 120Hz if you have a 127V/60Hz outlet...
Thanks for reading and feel free to improve and modify!
Thats interesting. I simply use power adapters "wall warts" from name brand manufacturers to power my LED's from the wall socket. It lessens the chances of having one burn my house down or getting electrocuted and killed. Used electronics stores usually have several hundred to rummage through to find one that fits your needs. For dimming, I use a rheostat inline with the LED.
The closer I can get here are old cell phone chargers. They will definitely reduce chance of burning the house down, but they are still expensive and less efficient than my simulation at very low power...
