Efest IMR18650 2600mAh (Purple) 2017
Official specifications:
Rated capacity: 2600mAh
Nominal voltage: 3.7V
Voltage at end of discharging: 2.5V
Max. charging current: 4A
Standard charge: 2A
Discharging current 25A
Pulse discharging current: 40A
Charging temperature range: 0°C ~ 45°C
Discharging temperature range: –20°C ~ 75°C
Inner resistance: 20mOhm
Cell size: 18.50 (±0.20)mm x 65.20 (±0.2)mm
A 2600mAh high current 18650 cell.
Nice tracking discharge curves with nearly constant capacity.
At 30A continuous discharge current the cell gets too hot.
Conclusion
This looks like a very good high current cell and it can easily deliver the rated 25A current.
Notes and links
The batteries was supplied by Efest for review.
Compare to 18650 and other batteries
