If you would like to purchase either of these products you can find them here. The Fluke clamp meter https://goo.gl/8JGdy9 and when you are ready to check out type in this coupon code 11annvele10%
The power supply https://goo.gl/6PVK3W and at checkout use discount code 92f7ee.
Many of the latest lights are still not available just yet so BangGood asked if I could review something else until they are ready. I agreed and this was a blast.
The review and testing that let you see how well both products work is all on video. It is getting to be a hassle to have photos hosted.
Most people do not even know and even some that do know refuse to admit that many Fluke meters are made in China. Makes no difference at all as they are excellent meters. Fluke is very strict about the quality and parts used.
The 362 is an certified true RMS clamp meter and it works and reads just as you would expect from a Fluke.
From the Manufacturer:
Thin, light, compact body design for one-hand operation
18mm triangular jaw allows for easy measurement on small cables
Large, easy-to-read backlit display
200 A ac and dc current and 600 V ac and dc voltage measurement range
3000 Ω resistance range, continuity detection
Zero function allows the display to be cleared for DC measurements
Data Hold function
CAT III 600 V safety rating
Range Resolution Accuracy
AC current 200A 0.1A 2% ± 5 digits (45-65Hz) 2.5% ± 5 digits (65-400Hz)
DC current 200A 0.1A 2% ± 5 digits
AC voltage 600 V 0.1 V 1.5% ± 5 digits (45-400Hz)
DC voltage 600 V 0.1 V 1% ± 5 digits
Resistance 300/3000Ω 0.1/1Ω 1% ± 5 digits
Continuity <=70Ω
General Specifications
Size (LxWxH) mm 205 × 60 × 22
Clamp opening 18 mm
Weight 196 g
Safety rating CAT III 600 V
Warranty 2 years
This was my first Gophert power supply and I had a lot of fun getting to know it. It will get used plenty.
From the manufacturer:
Model CPS-1610
Operation Voltage Range 95-132Vac OR 198 – 264Vac
Operation Frequency Range 45 – 65HZ
Output Voltage Range 0 – 16V
Output Current Range 0 – 10A
Efficiency (220Vac/full load) ≥ 87%
Full Load Input Current(220Vac) ≤1.4A
No Load Input Current(220Vac) ≤ 80mA
Volt Meter Accuracy ≤ 0.3% + 1 digits
Current Meter Accuracy ≤ 0.3% + 2 digit
Constant Voltage
Load Regulation (0-100%) ≤ 30mV
Line Regulation(198-264Vac) ≤ 10mV
Ripple & Noise (Peak-Peak) ≤ 30mV
Ripple & Noise (r.m.s) ≤ 3mV
Set Accuracy ≤ 0.3% + 10mV
Transient Response Time (50%-100% rated Load) ≤ 1.0ms
Constant Current
Load Regulation(90%-10% Rated Voltage) ≤ 50mA
Line Regulation (198-264Vac) ≤ 20mA
Ripple & Noise (Peak-Peak) ≤ 30mAp-p
Set Accuracy ≤ 0.3% + 20mA
Size(width× height× depth) 120×55×168mm
Net Weight 0.85KG
Both products arrived very well packaged and in perfect working order.
Measurements and testing will be in the video below. There would be nothing but a page filled with pictures if I had taken photos of each product working or any comparisons.
I hope you all enjoy the video and I promise you that both products were great and worked with no issues at all.
The URL and discount codes for each of them are listed at the top of the page. I need to thank BagGood.com for allowing the products for review as well as the discounts offered to anyone interested in purchasing.
Enjoy.
