ReyLight Pineapple mini (copper) AAA/10440 flashlight (OP Updated)
192 posts / 0 new
lucydog
Last seen: 3 years 4 months ago
WWEFANS, does this light use PWM? They’re beautiful!
charles lin
charles lin's picture
Last seen: 2 weeks 1 day ago
High frequency PWM is used on low & mid, not visible to the naked eye. The camera won’t capture the PWM unless you photograph the emitter directly in very close range, which you force the camera use very high speed shutter.
lucydog
Thanks!
DB Custom
DB Custom's picture
Last seen: 3 weeks 19 hours ago
How high speed is very high speed?
charles lin
I mean to said higher shutter speed. I don’t know the rational number of shutter speed. I can capture PWM on low mode at ExposureTime 1/24000. mid mode PWM at ExposureTime 1/66665.
DB Custom
DB Custom's picture
Geesh, and I thought my iPhone’s 1/50,000th was fast!
Ford Prefect
Ford Prefect's picture
Last seen: 1 week 14 hours ago
My Copper Pineapple has decided to eject its o-ring (between the lens and the head). Does anyone know a source for replacement or dimensions of the o-ring? I did get a couple spares with the light, but they were both the smaller ones for the head-body interface.
Thanks
Ford Prefect
ReyLight
ReyLight's picture
Last seen: 13 hours 40 min ago
Thanks
Ford Prefect
12*1mm
Bangarangy
Last seen: 9 months 2 weeks ago
Just picked one up from Amazon. Came with a v2 sticker on the box.
It’s absolutely gorgeous, but the twist UI is so finicky I’m finding it unusable. I have to untwist more than 1/2 turn to turn off, or else pressing the two halves together turns on the light (i.e. pressure in my pocket). This also means as I twist to turn it on, it often flashes and then ‘skips’ to the next mode because it momentarily activated and turned off while I was twisting it to turn on. I tried tightening down the driver as mentioned in a few places. My first attempt caused the front o ring to pop out, so I backed the driver out, lined everything back up and tightened it a little less than that. Didn’t seem to fix it for me. I have had the front o ring pop out a few times since then just from twisting the flashlight all the way ‘on’ until it stops.
Unfortunately I think it’s going back to Amazon. There really isn’t another AAA that I can find that looks this nice, but it has to work right.
ReyLight
ReyLight's picture
Sorry to hear.
LumenMax
LumenMax's picture
Last seen: 17 hours 9 min ago
Bangarangy wrote:
Just picked one up from Amazon. Came with a v2 sticker on the box. It's absolutely gorgeous, but the twist UI is so finicky I'm finding it unusable. I have to untwist more than 1/2 turn to turn off, or else pressing the two halves together turns on the light (i.e. pressure in my pocket). This also means as I twist to turn it on, it often flashes and then 'skips' to the next mode because it momentarily activated and turned off while I was twisting it to turn on. I tried tightening down the driver as mentioned in a few places. My first attempt caused the front o ring to pop out, so I backed the driver out, lined everything back up and tightened it a little less than that. Didn't seem to fix it for me. I have had the front o ring pop out a few times since then just from twisting the flashlight all the way 'on' until it stops. Unfortunately I think it's going back to Amazon. There really isn't another AAA that I can find that looks this nice, but it has to work right.
Not sure if you've noticed the new version: https://www.reylight.net/product/reylight-copper-pineapple-mini-aaa-10440-flashlight-nichia-219b-4500k-r9080-high-cri-led/. Tail switch, slot for tritium vial, glow ring in head, etc.
