Energizer 9V recharge 175mA NH22-175 (Silver-black)
Official specifications:
Chemical system: Nickel-Metal Hydride (NiMH)
Nominal voltage: 8.4V
Rated capacity: 175mAh at 21°C (0.2C/35mA discharge)
Typical weight: 42.0g
Jacket: Plastic
Operating temperature: Charge 0°C ~ 40°C, Discharge: 0°C ~ 50°C
Storage temperature: –20°C ~ 30°C
A 9V NiMH battery from Energizer, it is rated with fairly lowe capacity.
There is some difference between the two batteries, the variation with capacity is fairly normal for NiMH.
Conclusion
These batteries have a bit low capacity for 9V NiMH batteries, and the matching is not perfect.
I.e. not perfect batteries, but they are not bad either.
Notes and links
Compare to other 9V batteries: Alkaline/NiMH/Lithium/other
