Sanyo UR18650Y 1900mAh (Red)
Official specifications:
Rated capacity: 1850mAh
Minimum capacity: 1900mAh
Typical capacity: 2000mAh
Charging: CC-CV, 1330mA, 4.20V, 38mA cut-off
Maximum charging current: 1C
Discharge cut-off: 2.75V
This is a older high capacity cell (Datasheet from 2012), it is not designed to deliver high current.
The discharge curves matches very nicely, datasheet only shows discharge curves up to 2C, i.e. around 4A, but it can handle more.
Conclusion
This was a very good cell some years ago, today both the capacity and the current ability is rather low.
Notes and links
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
Compare to 18650 and other batteries
