Test/review of Charger PALO C906W
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 hours 8 min ago
Charger PALO C906W
DSC_9649
DSC_9653 DSC_9654
This is a fairly unknown brand of charger, it can charge and discharge up to D cells and also support 9V batteries.
DSC_9630
The charger did not include any box, but was only wrapped in bobble wrap.
DSC_9648
The pack included the charger, a mains cable and a instruction sheet.
DSC_9655 DSC_9656
The charger is mains powered and has DC socket, but it is not marked and I have not tried it.
DSC_9652
DSC_0711
The display shows the 4 batteries and charge, error and discharge indicators.
The button is used to switch between charge and discharge.
DSC_0708
Charging display, the batteries are animated.
DSC_0709
Discharging display, the battery show remaining charge.
DSC_9657
The indicator for 9V batteries is only a red led, the display is not used.
DSC_9658 DSC_9659
The slots are with a slider and large enough to handle from AAA to D sizes cells, between the slots are snaps for two 9V batteries.
supportedBatteryTypes
supportedBatterySizes
DSC_9660
DSC_9662
DSC_9663
DSC_9664
DSC_9665
Measurements charger
  • Power consumption when idle is 0.5 watt
  • 9V do not terminate
  • Without power it will discharge a NiMH battery with about 0.1mA
  • The charger will restart when a battery is inserted or power is cycled.
Charging 1.2V batteries
PALO%20C906W%20%28eneloop%29%20%231
This is a -dv/dt charging and there is no top-off or trickle charge when finished, this looks good.
PALO%20C906W%20%28eneloop%29%20%232
PALO%20C906W%20%28eneloop%29%20%233
PALO%20C906W%20%28eneloop%29%20%234
The other 3 slots are the same.
PALO%20C906W%20%28eneloopPro%29%20%231
The EneloopPro also got the same nice treatment.
PALO%20C906W%20%28leise25%29%20%231
But with the Leise the charger decides to use a 90mA trickle charge.
PALO%20C906W%20%28eneloopAAA%29%20%231
The AAA looks fine, but the current is a bit high.
PALO%20C906W%20full%20%28eneloop%29%20%231
A full cell is detected in about 13 minutes, this is fast for a -dv/dt charger. There is no top-off or trickle charge.
PALO%20C906W%20%284xeneloop%29
The charger maintains the same charge current with 4 batteries in it.
Temp5761
M1: 38.7°C, M2: 34.7°C, M3: 33.5°C, M4: 31.8°C, M5: 38.1°C, HS1: 42.7°C
The charger do not get very warm (I did this test with closed lid and only opened it for the photos).
Temp5762
M1: 33.7°C, HS1: 54.3°C
Poweron
The charger starts fairly fast and uses the usual pulsing to check the voltage.
Discharge 1.2V batteries
Pressing the unmarked button on the charger will start a discharge cycle.
PALO%20C906W%20discharge%20%28eneloop%29%20%231
The discharge current is only about 350mA and the charger will charge the battery when finished.
PALO%20C906W%20discharge%20%28eneloop%29%20%232
PALO%20C906W%20discharge%20%28eneloop%29%20%233
PALO%20C906W%20discharge%20%28eneloop%29%20%234
The other 3 slots looks similar.
PALO%20C906W%20discharge%20%284xeneloop%29
Running all 4 slots simultaneous the discharge current is the same, but for some reason the charger do not charge when finished with discharge (It did that when I did another run, but I did not record that).
Temp5750
M1: 36.5°C, M2: 35.6°C, M3: 34.8°C, M4: 33.6°C, M5: 42.3°C, HS1: 45.6°C
The charger uses a low discharge current, this means there it not much heat.
discharge
The discharge is with constant current.
Charging 9V batteries
PALO%20C906W%20%289V%29%20%231
The 9V charging is a much simpler and dumber charger, it will never terminate the charge current.
Voltage%20sweep%200-12V
Checking the charge voltage and current shows that the charging circuit is only a resistor.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
Nearly all the charge curves looks good, but it uses a high trickle charge once on a AA cell.
With 9V it is not a very good charge because it has no termination or indication on a full cell.
The rating for round cell is fairly good, but 9V is only usable.
Notes
The charger was supplied by Fasttech for review.
MRsDNF
MRsDNF's picture
Thanks HKJ. Beer
