Is my charger working?
5 posts / 0 new
wahoowad
wahoowad's picture
Last seen: 2 weeks 18 hours ago
This Rodee AD-108 charger is what I have been using for years for occasional charging duties for my 18650 cells. I only need to charge a couple cells a couple times a year.
https://www.dx.com/p/rodee-ad-108-lithium-battery-charger-for-18650-1767...
I left 2 cells in it overnight expecting they would be finished this morning, easily charging for 10 hours, but still had that red charging light showing this morning. I hooked it up to my Kill-A-Watt meter and see it is only pulling 0.07 amps. I swapped out the cells with a couple others and still the charger is only pulling out 0.07 amps from the wall.
Is it charging? I would expect it to pull more. My unit doesn’t have any specification printed on it to check.
Thanks
chadvone
chadvone's picture
Last seen: 2 hours 23 min ago
Read the reviews on the link you provided. “Strange Charger”
wahoowad
wahoowad's picture
ok. seems like it is working then
chadvone
chadvone's picture
Seams to be a slow charger, from what I read.
I’d check voltage of cell, then again after some time. See if there charging.
flydiver
Last seen: 4 min 4 sec ago
Sounds croaked, and not too hot to start with. You can get a decent Lii-202or 402 for a pittance at Bangood or Gearbest which would be a significant improvement, or you can go completely crazy, spend $20 and get an excellent analyzing charger. See HJK reviews. http://budgetlightforum.com/node/55264#new
Good pre-Black Friday sale going on at IMR. https://www.imrbatteries.com/black-friday/
Just about any of the Xtars are excellent.
To Air is Human, to Respire….Divine.
