Vapcell INR21700 3750mAh (Blue) 2018
Official specifications:
Model: INR20700
Nominal voltage: 3.6V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 3750mAh (0.2C discharge)
Min capacity: 2650Ah (0.2C discharge)
Weight: Max:70g
Internal resistance: Max:10mOhm
Standard Charge: 1500mA,CCCV 100mA cut-off
Charging Time: 3.5hours(standard charge)
Quick Charge Current: 3000mA
Max Continuous Discharge Current: 30000mA
Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~75°C
Storage: Temperature –5°C~35°C, Humidity <75%RH
Standard environmental condition: Temperature: 23±5°C, Humidity: 45-75%RH
The discharge curves for the two cells matches nicely and the cell is fairly constant in capacity at any current.
Conclusion
These cell looks to be good quality and can deliver up to the rated 30A
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
