Hi all,
I’m searching the web but feel a little bit confused.
please help my find the right batteries, and if you can - also charger.
I live in Israel and not all the products are shipping to my country.
Thank you guys.
Hi all,
Thank you guys.
Liitokala 50-A
pretty much any good quality 26650 will do the job
Thank you. Can you please tell me which one of the batteries is a good one?
as long as they are from brands like
Rebranded cells
Basen
Efest
Eizfan
Keeppower
Vapcell
Cell manufactorers
Liitokala
Shockli
Panasonic
Samsung
Sony
LG
they are good
avaoid any noname or brands with “fire”
you can always use the battery comparator of HKJ
https://lygte-info.dk/info/indexBatteriesAndChargers%20UK.html
https://lygte-info.dk/info/batteryIndex.html
Thank you Laxel. What about EBL?
EBL is poor cell quality stay away from it buy generic branded cells or from trustworthy rebranding companies
I use keeppower 5000mah. There is a gentlmen here that sells them in pairs for a good price. Look up doingoutdoors.com in the thread search. Should pull it up. Maybe someone here can lead you in the right direction to contact him. I also bought some from Mountain Electronics while they were on sale. Shokli brand I believe. Great cells. I also have some of the EBL’s and I know they get a bad reviews but I tested them in my lii-500 and got 4700mah to 4800mah and they have never let me down. I bought them when I first got into my lighting hobby. May not have bought them with the info I have read here but other than hearsay they have been great. Good luck, there are alot of good cells out there.
mAh is not the problem on cheap EBL cells its missing internal safety and poor internal resistance
do a discharge at 10A and you see how bad they break in
This
I’m not doubting there quality is not as good as other better known brands. Just saying before I knew better I bought some and for what I use them for they work ok. No, they don’t produce the output as others but they have all worked without issue. I don’t necessarily recomend them but they will work. Alot of people such as yourself just dismiss them but anyone who uses them on a regular basis could disagree with some of the negative remarks other say about them. I really think they are OK for lights or devices that do not require high output.
You might want to check NKON.nl - good choice, average price, quick delivery and only genuine brands with good performance.
thank you guys, I bought 4 Basen 5000mAh. you helped my a lot.
Hi. Please tell me what do you know about this, is it a real thing? GTF 8800mah? Purple
Bet they would be lucky to get 1500mah. I think it is ridicules that they are allowed to put those numbers on there.
Can I use 18860 in this flashlight?
As long as you have the 26650 to 18650 sleeve.
Can you give me example of this kind of sleeve
The cheap (clear) plastic ones work good but the black pieces with the rubber O-rings are great.
