Charger QC 2.0 for Charger nitecore UMS4
20 posts / 0 new
gotlib
Last seen: 8 months 3 weeks ago
Hello everyone
I’m out of luck: the charger nitecore ums4 is powered by a single micro usb port located here :
CHG-NITE-UMS4-8
the charger QC 2.0 is not sold with Sad
I have to buy it
the site nitecore says : DC 5V/2A 12V/1.5A / 18W (MAX)
do you think this charger qc 2.0 is 100% compatible? :
https://www.aliexpress.com/item/ORICO-QCW-1U-1-Port-QC2-0-5V2-4A-9V2A-12V1-5A-Desktop-USB-Quick-Charger/32664055648.html?spm=2114.search0104.3.2.f78260dfc0pFpT&ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_319_10892_317_10696_453_10084_454_10083_433_10618_431_10304_10307_10820_10821_537_10302_536_10843_10059_10884_10887_100031_321_322_10103,searchweb201603_52,ppcSwitch_0&algo_expid=e22f30c3-64cf-4e23-8c4f-260cbd576253-0&algo_pvid=e22f30c3-64cf-4e23-8c4f-260cbd576253
I also found this one but it is 36W is not good? :
https://fr.aliexpress.com/item/Qualcomm-Certified-Aukey-Quick-Charge-2-0...USB-Turbo-Wall-Charger-Fast/32598700109.html?af=171752&aff_platform=aaf&cpt=1548377064595&afref=&cn=15643&dp=12%253A%253A171752%253A%253A0800ko9ug65r%253A%253A%253A%253A1548377064&cv=12&pvid=d7ac01a0-9772-4445-8086-9b0f30330851&sk=Y7bAZbY&aff_trace_key=531c06fe497b4e48901faea9bf7fe518-1548377064595-04195-Y7bAZbY&rmsg=replace_same_item&scm=1007.23534.124736.0&terminal_id=9f824339d18e43d3b4c49e070b82398d
would you know if there are cheap QC 2.0 chargers again better than those 2? Smile
thank you in advance for your help
Edited by: gotlib on 01/24/2019 - 22:33
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 5 hours ago
Both will work fine.
However, something like this:https://fr.aliexpress.com/store/product/Aukey-Wall-charger-Qualcomn-Quic...USB-ports-EU-US-Plug-Wall/1830134_32655938483.html
Would be even better for the future, since it supports QC 3.0(more efficient protocol, can also use it for your smartphone) and USB-C.
Anyway, all choices are from great brands, so I would not worry.
gotlib
I thank you for your super fast response BlueSwordM Wink I think i’ll take the one from your link, but QC 3.0 will not charge the batteries too quickly or disrupt the nitecore charger?
BlueSwordM
No, nothing.
QC 3.0 is backwards compatible with QC 2.0, and backwards with regular USB 2A charging.
So no problem there Smile
gotlib
BlueSwordM wrote:
No, nothing.
I thank you for this explanation.
but another question worries me:
the usb cable connector aukey of your link is a micro USB type C. While the USB connector of the cable nitecore ums4 is a micro USB type A i think. pic :
zeroair-reviews-nitecore-usm4-usm2-charger-13
then will the nitecore charger support or accept a C-type connector?
BlueSwordM
No, the USB-C connector is just a bonus inside of the package for other things like your phone/future USB-C lights. Smile
Since the micro-USB is included, it should not be a problem.
gotlib
in fact i did not understand the connection i apologize.
I will use the cable given by nitecore, i plug the micro usb side on the nitecore charger and the other side usb i plug it into your aukey charger and it works? Smile
BlueSwordM
Yes, absolutely Smile
gotlib
I am super reassured thank you for your help soon Smile
Blackbeard
Blackbeard's picture
Last seen: 4 hours 2 min ago
you can plug it into a computer usb port as well
gotlib
cool thanks for this info it can be useful Smile
on my pc i have ports usb 3.0 but at maximum they can go out only 5V?
with the nitecore charger ums4, if i want to charge my 4 battery 18650 together at 1 amp, the 5V will not be enough?
HKJ
HKJ's picture
Last seen: 3 days 17 hours ago
A QC charger is a QC charger, I have not seen any that did not work as expected:
https://lygte-info.dk/info/ChargerIndex%20UK.html
The UMS4 do not need a QC charger to work, it only makes it slight faster in some situations. My review will be published in a couple of weeks.
gotlib
HKJ wrote:
A QC charger is a QC charger, I have not seen any that did not work as expected: https://lygte-info.dk/info/ChargerIndex%20UK.html
I saw your link and yes indeed they all work very well. except those with the death head in safety Big Smile
thanks for this info . So to pay less i should have to take a non-QC charger?
if yes, i will have bought one, but as on my charger nitecore it was written: DC 5V/2A 12V/1.5A / 18W
looking for a usb charger of 18W i found only QC …
HKJ
HKJ's picture
gotlib wrote:
thanks for this info . So to pay less i should have to take a non-QC charger? if yes, i will have bought one, but as on my charger nitecore it was written: DC 5V/2A 12V/1.5A / 18W looking for a usb charger of 18W i found only QC …
With a non-QC charger the maximum charge power is reduced a bit, but that do not prevent the charger from working.
gotlib
ha ok Smile but what i mean is that i did not manage/succeed (sorry for my poor english) to find a non-QC charger respecting these specifications: DC 5V/2A 12V/1.5A / 18W
HKJ
HKJ's picture
A non-QC charger would only have 5V 2.4A and there are a lot of them.
gotlib
ah yes like my charger usb galaxy s4 . Thank you for these explanations, good evening Smile
BlueSwordM
Just use the QC 3.0/2.0 charger so you can charge multiple 18650/21700s at 1A.
Charging large cells can be quite the hassle at 500mA, so 1A is quite good.
gotlib
thank you BlueSwordM for this info that interests me Wink
Blackbeard
Yeah I dont know how many watts a PC output has, but if you want to do 4 at 1 amp it might not work so maybe you would need the reccomended/max wattage Nitecore manual says, but you can probably do 1 or 2 batteries at 1/2 amp from PC, but I’m no expert
