MS12.2 - emitter upgrade
11 posts / 0 new
mattjk
mattjk's picture
Last seen: 4 months 4 days ago
Thought it may be useful to anyone who wants to upgrade theirs to 70.2
I wish I had taken more pictures
Bezel, glass and reflector removed, it is glued, but after being run on turbo a few times weakens it. Soldering quality not the worst but not the best.
Desoldered and MCPCB removed, lots of thermal interface paste! There is a brass insert/plug which I believe is attached to the primary heatsink that the fan surrounds.
Emitters desoldered, I found the best way was to use the back of a cast iron pan on the gas hob, as trying to maintain temp on a large MCPCB using hot air was challenging.
Not impressed with the poor adhesion, probably a contributing factor in the high failure rate of the DX80, in my opinion they have used a solder with a low flux content to avoid having to manually clean the board.
While the board was hot, i took the chance to clean off the old solder (I wish I had got a pic but the contact between the thermal pad and board was not great)
The resistors are just 0 ohm bridges for 12V Cree configuration. I am not sure why they didn’t just increase the heatpad like this
http://kaidomain.com/S025183-16mm-x-1_5mm-DTP-Copper-MCPCB-for-CREE-XHP70-12V
New emitters flowed on using good old 63/37 leaded solder, bit of a mess with the flux.. Top tip, clean it off while its cooling with an artists brush and 99% IPA
Tested each one, to my surprise they all worked first time.
Board cleaned, PCB varnish applied to resistors, ready for reinstall.
Reinstalled with MX4 and resoldered
Success!
power911
power911's picture
Last seen: 3 weeks 1 day ago
call it insufficient pics, but I’d say that’s a balanced amount of quality pics.
very clean transplant. Loved it.
“Have you forgotten about all those who called you a Bringer of Woe and hunted you like an animal?”
“Normal humans don’t go around killing people and burning towns!”
“Don’t worry. I’ll go with you! So you just follow me and no arguing, okay?”
mattjk
mattjk's picture
Thanks buddy
Lumeniac
Lumeniac's picture
Last seen: 4 hours 8 min ago
Tnx!
mattjk
mattjk's picture
Maybe hold fire on this, just had a battery cut out, i think perhaps in turbo it runs a direct drive and cant handle it.
MascaratumB
MascaratumB's picture
Last seen: 21 min 1 sec ago
Beamshot required Big Smile Evil
Nice work Wink
MRsDNF
MRsDNF's picture
Nice work on the mod. Well done. Beer
AlexGT
AlexGT's picture
Last seen: 2 days 5 hours ago
That factory re-flowing sucks big time, nice job on the clean replacement of those leds, what did you use as a hot plate for reflowing?
mattjk
mattjk's picture
It’s a no go anyone considering this. I think its direct drive on turbo and when its hot (lower resistance) it trips the battery safety short circuit. Oh well lol
djozz
djozz's picture
Last seen: 1 hour 6 min ago
You could use slightly lower drain batteries, see if that helps.
Great led swap btw, and amazing that expensive flashlights are delivered with such lousy-soldered leds.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 3 months 5 days ago
No, MS12 has a battery pack, its not possible to use other batteries.
