BLF Q8 diffuser (lantarn)?
28 posts / 0 new
ZoomieFan
ZoomieFan's picture
Last seen: 4 months 5 days ago
Is there anything that can sereve a diffuser for a BLF Q8?
The Q8 great but a bit bulky to EDC and the max output to high for my needs.
A have a Tool 2.0 AA/AAA and they give an amazing amount of light using a diffuser.
That makes me think my Q8 at 1100lm with diffuser would be a great lantaren.
It will be a work light, so it shouldn’t be to fragile.
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88 4/5, LiitoKala: 3x100 3/5, 2x202 3/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: DQG Tiny III 26650 5/5, DQG Tiny III 18650 5/5
FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Skillhunt H04FRC 4/5, Sofirn C01 BLF 3200k/5600k 2/5, Zebralight H600Fc 3/5.
Powerbanks: Romoss 30000 4/5, xiomi 1000 4/5, Xtar PB2 4/5, Xtar PB2S 5/5
Edited by: ZoomieFan on 04/04/2019 - 07:13
kiriba-ru
kiriba-ru's picture
Last seen: 3 weeks 2 days ago
Im using a suitable diffuser from led lamp.
Not best option, but I was not ready to wait several years until blf q8 lantern will be ready.
Tony Cape
Tony Cape's picture
Sofirn sells the diffuser on their Aliexpress store.
Agro
Agro's picture
Last seen: 4 hours 41 min ago
I like these:
https://www.aliexpress.com/item/Brand-Headlamp-lantern-Camping-Lamp-Cove...
Expensive but small, light, universal and work well enough.
djozz
djozz's picture
Last seen: 2 days 5 hours ago
Agro wrote:
I like these:
I have one of those, it has got no real use yet, but it works very effectively turning the Q8 into a lantern
ZoomieFan
ZoomieFan's picture
Just bought this one
Maybe I try the bag one later but I think that with my use it will get muddy very soon Smile
L version?
Rat_Racer
Rat_Racer's picture
Last seen: 1 year 4 months ago
L version?
Here: http://budgetlightforum.com/node/44923
ZoomieFan
ZoomieFan's picture
I’ve seen that thread. I’m just looking for upgrade for my Q8.
Agro
Agro's picture
L version?
S is for tiny lights, L for larger ones.
Q8 is a tiny light so S should be fine. Wink I can check when I’m back home.
Diomedes
Diomedes's picture
Last seen: 3 years 2 months ago
I really like the Fenix AOD-L. It fits on snug so doesn’t fall off or move about and it diffuses the beam very nicely when I use it inside. I’ve bought one from hkequipment and one from Kaidomain. I’ve found hkequipment tends to ship a little faster than KD, at least in my experiemce (in case you want it quickly).
https://www.hkequipment.net/product-p/aodl.htm
http://kaidomain.com/S025495-Fenix-AOD-L-Diffuser-Tip-for-TK40-TK41-TK60
ZoomieFan
ZoomieFan's picture
Does it well fit on the Q8?
Diameter of the Q8 is 59mm and the Fenix diffuser has a diameter of 63mm
I have Lumintop Tool 2.0 AA/AAA with a silicone differs and a Nitecore LC10 with a PVC (I think) diffuser.
The Lumintops have a much more pleasant light. Doesn’t hurt my eyes at all when looking in the light.
Diomedes
Diomedes's picture
Yes, fits on the Q8. That’s what I use them on. The opening is larger so the Q8’s bezel sits about 2cm inside the diffuser where it tapers in. A gentle press down fits it quite tightly to the bezel.
Boaz
Boaz's picture
Last seen: 47 min 23 sec ago
  I've never been a fan of wand style diffusers since they generally become like a bare light bulb and be unbearable to even be around . So my default is to run flat diffuser film and even then on a light like the Q8 to make a lens cap type one that will pop on and pop off easily .
 If you must run a wand diffuser I like ones that let lots of light out the top and not so much out the sides.
It's a matter of using a different type of plastic .One like is commonly used as a medical specimen testing or test sample container .
Like >>>
                 υμεις εστε το φως του κοσμου ου δυναται πολις κρυβηναι επανω ορους κειμενη
deleted-200707
Last seen: 2 years 2 months ago
Used ones can be way too yellow. Silly
Lightbringer
Lightbringer's picture
Last seen: 5 min 36 sec ago
Boaz wrote:
I’ve never been a fan of wand style diffusers since they generally become like a bare light bulb and be unbearable to even be around .
This.
Even on my Aider/Ultratac/whatever AAA light with diffuser, the paltry amount of light concentrated into a small area just grates on me after a while. I much rather use ceiling-bounce.
Unless you’re glamping and would have to use “tent-bounce” for light, I’d use something other than a diffuser. But if you’re stuck with that as the only reasonable solution, yeah, the above suggestions should work fine.
ZoomieFan
ZoomieFan's picture
That’s so with this light: https://flashlight.nitecore.com/product/la10
But not so (imo) with the Lumintop tool https://lightsandgadgets.files.wordpress.com/2018/09/20180902_174853.jpg...
That’s relaxing light. No idea why, it’s bright and very white. Perhaps the silicone filters out UV?
ZoomieFan
ZoomieFan's picture
Basement/crawlspace bounce Smile
Lightbringer
I’d be happy with a flashlight equivalent of a “cone of shame” that dogs wear to keep from biting at stitches, wounds, etc.
Would still direct diffuse light forward, but keep it from shining back in my face. Even holding it directly away from me, there’s enough arm-length parallax to expose the bright glowy bits to both eyes.
ZoomieFan
ZoomieFan's picture
Could be a nice option. Has a tracking system and runs 5 hours on a bone Smile
LouieAtienza
Last seen: 3 years 4 months ago
I recently took apart a few LCD TVs at work and salvaged parts for repair work. I also salvaged the diffuser film used for the backlight. Nearly 180 deg. of light, almost no glare. Like it enough to put in a Maglite 2AA and some Defiant flashlights, as well as a couple 6V lanterns we use at work for general lighting tasks.
Agro
Agro's picture
L version?
Just checked. They say 65 mm diameter but Q8 is a tight fit. Took me like a minute on the first (slightly drunk) try. Surely could be done way faster with experience. L would be much easier but then it would be so large…
I’m not sure which one to recommend but probably S. Smile
deleted-200707
Sounds a bit like my prom night.
ValuseekeR
I bought a cheap lambency diffuser for mine. It works, but does create the bare light bulb effect so I haven’t used it much. Indoors,ceiling bounce is usually preferable to me. Otherwise I’m patiently waiting for the BLF Lantern.
Lightbringer
Wellp, anyone wantsa get crazy, get a clear jug of water, set it atop the Q8, and add just a few drops of milk for the amount of “haze” you want in it.
The bigger the jug, the more diffuse the light, and less bare-lightbulb effect.
Me, I’d just stick with ceiling-bounce.
toddcshoe
toddcshoe's picture
Last seen: 5 days 5 hours ago
I made this one from a plastic tumbler. I just sanded it to dull it up and diffuse more of the light. Took only 10 minutes and didn’t cost a dime. Already had the cup sitting in the cabinet unused. I am not a fan of most diffusers. Too small and too milky white looking for my taste. I like warmer looking for out on the patio table or deck.
lantern
"Everywhere I go, there I am"
Unloco
Unloco's picture
Last seen: 4 days 13 hours ago
disposable plastic cup
CJ Avlis
Can confirm…fits and works well.
Rexlion
Last seen: 2 days 21 hours ago
I saw a thread about using an orange Gillette Fusion shaving gel cap to warm up the light from a Streamlight Siege lantern. It got me wondering. I had a can of the stuff under the sink, so I took the cap and set it onto my Q8. Lo and behold, the cap sits just inside the bezel (it fills the space, but it doesn’t readily “snap in” or hold, so it might only work for stationary tail-standing) and this cap creates a wonderful lantern light. What amazed me the most was the lack of glare! Apparently the curved, dome-shaped cap does not send as much light straight sideways as one gets from a vertical diffuser surface. I have a white diffuser tip that came with a Maratac AAA twisty, and that thing makes way more glare than this shaving gel cap on a Q8 ramped up about 2/3 of max. Not sure I’d want to use this cap on max 5K lumens, it might get too hot.
Until the LT1 ships, I think this might serve as a passable substitute while camping inside my cargo trailer. I have a high shelf built on one side that is just above eye height. For outdoors too much light will be wasted to the sky from this rig, but I have a Siege on the way also.
== We save the planet from darkness ==
