These are Lusterfire flashlight Reflectors,the pictures are as below ,Any need please let me know,
The updated flashlight refelectors size are as below ,Thank you!
28.5 mm x21.5 mmx(7mm LED hole in)
42 mm x32 mmX(7mm LED hole in)
59.6 mm x39.9 mm x(15mm LED hole in)
36 mm x28 mmx(7mm LED hole in)
45 mm x20 mm x (8mmx3pcs LED hole in)
53 mm x28.6 mmx(8mm LED hole in)
23 mm x19.7 mmx(6mm LED hole in)
26.5 mm x22 mm x(8mm LED hole in)
43 mm x36.6 mmx(7mm LED hole in )
22.5 mm x17.5 mmx(8mm LED hole in)
33 mm x25 mmx(6mm LED hole in)
25 mm x17 mm x(8mm LED hole in)
25.5 mm x20 mmx(8mm LED hole in)
20 mmx11mmx(5mm LED hole in )
23 mm x23mmx(5mm LED hole in)
Any quesion please let me know
Lusterfire
In this international forum I've never seen anyone say “cups”, we use the term reflector. If someone makes a search in the forum he/she will type “reflector” and hence a thread with the title “flashlight cups” will not be found. Or very hardly.
Thank you for the PM Lusterfire you might want to edit your first post to add the dimensions, here are the reflector specs you kindly sent to my PM
“Quote from Lusterfire”
@Lusterfire
You wouldn’t happen to have or be willing to make a few 19mm diameter by 12.5mm height and a 5mm hole opening reflectors?
A few of us would like to replace the reflector in the old model Jetbeam RRT-01.
