Test/review of Energizer Ultimate Lithium AA 2019
12 posts / 0 new
HKJ
HKJ's picture
Last seen: 20 hours 19 min ago
DSC_6908
Official specifications:
  • Nominal voltage: 1.5V
  • Chemical system: Lithium Disulfide (Li/FeS2)
  • Storage temperature: -40° ~ 60°C
  • Operating temperature: -40° ~ 60°C
  • Maximum discharge current: 2.5A
  • Maximum pulse discharge current: 4A (2s on / 8s off)
  • Shelf life: 20 years at 21°C
Energizer%20Ultimate%20Lithium%20AA%202019-info
DSC_6902
DSC_6903
DSC_6904
DSC_6905
DSC_6906
DSC_6909 DSC_6910
DSC_6911
DSC_6912
DSC_6913
Energizer%20Ultimate%20Lithium%20AA%202019-Capacity
Being lithium batteries means they maintain close to 1.5V until they are nearly empty. It looks like this battery has some sort of over current protection.
Energizer%20Ultimate%20Lithium%20AA%202019-CapacityTime
Energizer%20Ultimate%20Lithium%20AA%202019-CapacityTimeHours
Discharge%20Energizer%20Ultimate%20Lithium%20AA%202019%200%2C01A
Discharging at low current (10mA) shows the higher voltage (1.7V) from these batteries, but there is no extra capacity to be gained.
Energizer%20Ultimate%20Lithium%20AA%202019-Energy
Conclusion
These battery are the best primary batteries around, but also rather expensive and some equipment may have problems with the high voltage.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
Superstocker
Superstocker's picture
Last seen: 4 hours 14 min ago
Wow those do look nice for 1.5v primaries. Thanks HKJ!
LightObsession
Last seen: 1 month 1 week ago
Thanks for testing those.
Terry Oregon
Terry Oregon's picture
Last seen: 1 week 3 days ago
These go in all my auto flashlights, because they hold up well in varying temperatures - and have a long shelf life. I also put them in all my remotes, because I know that leaking is rare.
I've done a few runtime graphs on various lights with these and compared their runtime with Panasonic Eneloop pros.  In general, you will get about 1.5 times the runtime.
My reviews: , My personal collection of lights LINK,  J5 Tactical V1 Pro review LINK,  Thirteen Optical Sensors review LINKZebralight SC700d review LINK,  Ray-O-Vac Super Power Sportsman review LINK,  Convoy S2+ color combos LINK,  How To flash D4V2 LINK.
will34
will34's picture
Last seen: 15 hours 42 min ago
Thanks for the test, they seem to perform great! 5Wh in a AA cell is just insane.
The only downside is they’re extremely expensive compared to alkalines.
WalkIntoTheLight
Last seen: 8 hours 3 min ago
Yes, nice batteries, but insane prices where I live. They cost $2-$3 each. At that price, I can get Eneloops for about the same cost.
It’s interesting that the Energizers are only good up to about 2 amps. I guess that’s plenty, but still not enough for high-demand lights like a Zebralight SC5. I guess Eneloops still rule as far as power goes, though not in capacity.
The only time I could justify the price of Energizer Lithiums, is if I was using them in weather below -20C. Eneloops start to suffer below that temperature. If the Energizers are good to -40C, they’d have value in extreme cold.
Kame Sennin
Kame Sennin's picture
Last seen: 8 months 5 days ago
Thank you for the test
I use the AA ones for the small torches (like SF10)  i gift to "non technically inclined" people.
At least there is a decent chance it will still work and won't leak after being tossed in a purse or glove compartment and left there for monthes/years
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 12 min 54 sec ago
Has anyone used these cells in DMM devices yet? I want to use them in my Aneng AN8009 multimeter but I'm not quite sure about the higher voltage of these cells and if there's a risk to damage the DMM or that measurements will be wrong due to too high input voltage.
HKJ
HKJ's picture
Lux-Perpetua wrote:
Has anyone used these cells in DMM devices yet? I want to use them in my Aneng AN8009 multimeter but I’m not quite sure about the higher voltage of these cells and if there’s a risk to damage the DMM or that measurements will be wrong due to too high input voltage.
The Aneng probably uses a DTM0660 chip and these are rated for 3.6V, that means 1.8V for each battery, i.e. it is fine to use lithium-iron batteries. There is a reference both in the chip and the meter that will keep the meter correct independent of supply voltage.
Lux-Perpetua
Tak for oplysningerne Henrik! Thumbs Up
Barkuti
Barkuti's picture
Last seen: 1 hour 19 min ago
HKJ wrote:
… looks like this battery has some sort of over current protection.
Concerning this, does the cell dies if the protection trips in? I.e., does the protection self-resets?
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
HKJ
HKJ's picture
I will assume it do, it is most likely a PTC.
