Test/review of Shockli CR2 1000mAh (Yellow)
9 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 25 min ago
DSC_8357
Official specifications:
  • size(mm): 15mm(Diameter) x 27mm(Length)
  • Weight(g): 16±1g
  • Voltage: 3.0V
  • Capacity: 950mAh-1000mAh
  • Discharge Cut-off voltage: 2.0 V
  • Non-Rechargeable: CR2 can not recharged
  • Discharge Current: 0.1A- 0.7A
  • Head Type: Button top
  • Protected: With PTC protection
Shockli%20CR2%201000mAh%20(Yellow)-info
Shockli is normally known for rechargeable LiIon batteries, but they do also have a primary CR2 cell.
DSC_8354 DSC_8355
DSC_8356
DSC_8358 DSC_8359
DSC_8360
DSC_8361
DSC_8362
Shockli%20CR2%201000mAh%20(Yellow)-Capacity
Output voltage depends on load, this will also affect total capacity.
Discharge%20capacity%20Shockli%20CR2%201000mAh%20%28Yellow%29
At low current the output voltage will be higher and more capacity can be used.
Shockli%20CR2%201000mAh%20(Yellow)-CapacityTime
Shockli%20CR2%201000mAh%20(Yellow)-CapacityTimeHours
Shockli%20CR2%201000mAh%20(Yellow)-Energy
Conclusion
It looks like a good CR2 battery.
Notes and links
The batteries was supplied by Shockli for review.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
CRX
CRX's picture
Last seen: 9 hours 7 min ago
Thumbs Up
Superstocker
Superstocker's picture
Last seen: 2 hours 13 min ago
Thanks HKJ!
MascaratumB
MascaratumB's picture
Last seen: 5 hours 25 min ago
Thanks HKJ! May be looking for some of these if the price is right for my Nebo Redline Micro! Unfortunately I cannot find CR2 batteries that can be charged or some equivalent Oops
Nichia
Last seen: 1 month 1 week ago
 Thank you very much for your continues effort and amazing work as always.
 Are these good for the muyshondt aeon mk iii please ???
Nichia 219B
DavidEF
DavidEF's picture
Last seen: 1 week 6 days ago
According to Wikipedia List of Battery Sizes, it is 15270. There are some for sale on Amazon.com I don’t know if you can buy from Amazon, but they should be available in AliExpress or something.
- The YKK Philosophy
MascaratumB
Thanks DavidEF!
I should have searched more before!!
I can buy from Amazon but I will take a look at AliExpress, as I’m more used to buy from there!
Although I don’t use the flashlight often , having rechargeables will spare me some money and allow me to use it more often!
Btw, these Shockli cells don’t seem to be available yet on their AliExpress store!
DavidEF
DavidEF's picture
MascaratumB wrote:
Thanks DavidEF!
Check to make sure the flashlight works with the voltage of the cells. Usually, Lithium Primaries are either 3.0 or 3.2 volts max, where Li-Ion goes to 4.2 volts and even LiFePO4 is 3.7 volts when fully charged.
Shockli-Simon
Shockli-Simon's picture
Hi BLF number, GOOD DAY
Shockli New release – Shockli CR2 3V Lithium Battery 1000mAh is available in US Amazon
-Shockli CR2 3V Lithium Battery 1000mAh
-Capacity: 950mAh-1000mAh
-Work Voltage : 2.0V – 3.35V
-Discharge Cut-off voltage: 2.0V
-Non-Rechargeable: Can not recharged
-Shelf Life: 10 Years
- Ideal for : Smoke detector, Range Finder, Green laser
Customer Instructions
-Non-Rechargeable, please do not charge
-The size is 15270, the diameter is 15mm, the length is 27mm
USA amazon store
You can search the “cr2 battery” in us amazon, USA BLF number can PM me on BLF or email to sales@shockli.com, I will give $2 promotion code, you can get 8pcs in $ 8.99, we only sell on USA amazon, do not sell on other amazon
