[M4D deal] 21700 FW3A presale list
309 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 1 day 18 hours ago
Flashaholics wrote:
Lumintop have told me only a 75mm+ protected cell will fit in batch one.
If it was my light, I would simply stretch the tail spring to make it longer. Or maybe swap in a longer spring. Or add a solder blob on to the button top. Easy fix.
The_Flashaholic
The_Flashaholic's picture
Last seen: 4 days 9 hours ago
I can do that but, I won’t recommend it in a review
My 4K Lumen Whore Reviews (MS18, X70, MS12, DX80, X80-GT, X45vn etc) - http://www.youtube.com/c/FLASHAHOLIC_TV
M4D M4X
M4D M4X's picture
Last seen: 1 year 1 month ago
how long are your tubes?
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
The_Flashaholic
85mm
M4D M4X
M4D M4X's picture
 WTF??
Please send me a picture of the measurement
I need to inform some people about that
PLEASE NOTE
mortuus
mortuus's picture
Last seen: 10 hours 27 min ago
it says on banggood the current batch does not fit flat tops unprotected like fw3a.. so the question is , why did lumintop sent that batch to banggood? kinda useless if normal 21700 unprotected suddenly are too short… this is something u shouldnt have to worry about.
Quote:
*This is a early version of the FW21 that has a longer battery tube than the later production FW21’s have. This version does not support unprotected 21700 batteries as they are too short causing intermittent operation. If you can find high drain protected 21700’s you should be OK. Unprotected 18650’s will work with the supplied adapter though what is the point. Might as well by a FW3A. Wish I had known this before hand. *
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
highzlik
Last seen: 1 month 1 week ago
About longer tubes..
I have also first batch from BG and I wrote to Lumintop if I can get shorter second batch tube and they told me that tube is the same on both batches but second one has longer springs.
So they recommend me to swap spring for longer one.
Ive swapped the tail one for spring from led4power and all cells now fit perfectly without rattling and poor contact Wink
Garik F
Last seen: 7 months 2 weeks ago
Hello, do someone know, where can I buy FW21 (not FW21 Pro)? Just can’t find it anywhere, only pro version
