[Review] Convoy S12 - the best Convoy's flashlight?
82 posts / 0 new
Yokiamy
Yokiamy's picture
Last seen: 3 hours 17 min ago
oweban wrote:
Yep! Added an R050 to my S11; 7.2A is close to perfect for SST40 Wink
Funny, i added an R050 as well Wink
Mocarny
Mocarny's picture
Last seen: 18 hours 21 min ago
Temperature sensor bothers me in M3, but in S12 flashlight gets really hot before step down, so I assume inside is really hot, I definitely want to keep it.
But this sense resistor in SST40, tell me more Glasses Where to solder it?
If you struggle choosing your perfect headlamp, check my headlamp guide, I compared 15 most popular headlamps there: CLICK
oweban
oweban's picture
Last seen: 5 months 4 weeks ago
That’s the sensing resistor – if you run something in parallel with it, it’ll adjust the maximum amps. I’ll list the final current if you add one of the below resistors in parallel:
  • R010 – 12A
  • R015 – 10A
  • R020 – 9A
  • R025 – 8.4A
  • R050 – 7.2A
Note that they’re 2010 (5025) resistors – I found it hard to find a mix bag of low resistance in 2010/5025; I got them in 2512 (6332), so the new one overhangs a bit.
Chronovore
Last seen: 3 days 9 hours ago
Nice review. I don’t usually see people who describe as being allergic to warm light. I like things golden. Green is a funny color. Green seems to pop with cooler light, whereas some of the background colors come out more with warmer light. For instance, birch trees in summer look great under cool white at night. Mixed forest scenery looks more alive with warmer light.
Mocarny
Mocarny's picture
Maybe the problem was this Wizard Pro NW 5700K, so after switching to S12 it was looking more yellowish than it should. Now I think, maybe I should have small AAA size 2700K light, to shine a bit before S12, so the S12 would look very neutral Silly
I see, so stacking, not replacing this existing, thank you Wink
hasddie293
hasddie293's picture
Last seen: 7 months 1 day ago
So I’m guess everyone that own s12 has probaly seen how the beam profile look like. Well, it not look round due to reflector designed for 3 leds. It look like a shield shape.
But not just that, if you remove the stainless benzel away, you will yet see a different beam profile or should I say beam edge? you will noted a really nice flower-paddle shape beam. You guy try it on a white wall and I bet you’ll see the different…
It seem to me that, without the benzel look very nice beam edge than with benzel. But, the thing is, benzel is use for cover the lens from stick out… Facepalm
Just my opinion though, any guess how this happen?
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
oweban
oweban's picture
I’ll take a look tonight – I like the petal shape beam, but the four notches in the bezel makes an extra line in it, and they’re not necessary.
SKV89
Last seen: 6 days 3 hours ago
The thermal regulation and performance of this light looks great. Thanks for the review.
Mocarny
Mocarny's picture
With bezel the beam looks like a fat triangle, and without like a flower.
So…if you like fat triangles, use the bezel, but if you like flowers – remove that bezel Thumbs Up
Lumeniac
Lumeniac's picture
Last seen: 3 hours 21 min ago
nice pics, thanx
mattlward
mattlward's picture
Last seen: 5 hours 30 min ago
  • R010 – 12A
  • R015 – 10A
  • R020 – 9A
  • R025 – 8.4A
  • R050 – 7.2A
So the stock resistor is a .1 ohm if I am reading the tables correctly? This would be 10*.01=ohms?
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
oweban
oweban's picture
R010 is 0.01 ohm – what I did was use this:
http://www.sengpielaudio.com/calculator-ohmslaw.htm
In the top set, 6 I and 0.01 R, gives 0.06v sensing – threw that in the second one along with common resistors (eg. R025 etc, 0.025 I) and it gave off the amps that would be added to 6A by putting that in parallel.
1stein
1stein's picture
Last seen: 8 min 30 sec ago
hasddie293
The best version?? I could say it YES
I own XT21X which used 21700 and now barely used them, since S12 came by, I like much of the tint, yet compact lighter and brighter. I loved it.
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Mocarny
Mocarny's picture
1stein wrote:
Red version build
Nice build Thumbs Up
SO much red light, I used to like red light because of night vision, but it’s too uncomfortable for me now.
1stein
1stein's picture
Mocarny wrote:
1stein wrote:
Red version build
Nice build Thumbs Up SO much red light, I used to like red light because of night vision, but it’s too uncomfortable for me now.
Thanks. I agree, white light is way more comfortable. RED looks like 0 CRI with black pools. Sometimes scary Shocked but has advantages too.
Why do you write “now”? Has there happened anything making red light less comfortable for you than it used to be before?
Mocarny
Mocarny's picture
Hmm let me think… Previously I was fascinated about red light – it’s very good for night vision, so good for sky watching. But now I’m not as fascinated in sky and stars and flares as before, so I’m not using it. It would be still nice to have a red light in my headlamp, but 30lm red light is for just illuminating things near me, not for walking – I can’t find practical use for red light now.
Isn’t it uncomfortable for eyes to walk with your red light for e.g 20 min?
1stein
1stein's picture
It is. After a while I feel like on a different planet but maybe it just requires getting used to it. And it looks much better in accompany of other light, moon light or dusk/sunrise. In complete darkness it feels like getting inside Diablo 3 Evil
Mocarny
Mocarny's picture
It is said that red light helps to fall asleep…so be careful when walking with that much of red light, because you can suddenly fall on the ground and fall asleep. Shocked
pipa
Last seen: 1 year 3 days ago
Got myself a S12 SST-20 4000K.
Almost perfect. Almost the best convoy light.
Wonderfull shape, design, haptics, optics, beam, tint, 21700, mode spacing, temperature control.
but:
UI just middle age. Massive downgrade from biscotti UI.
Wanted to see it with my own eyes,
but the light will end up unused because i very much dislike unpredictable start mode.
Mocarny
Mocarny's picture
I personally like this UI – it is simple, 4 modes and that’s it. We have Andurils and other complicated UIs, but here is simple UI for non flashaholics too. And Convoy seems (for me) to start making flashlights like for some kind of apocalypse – very thick walls and glass, simple UI. M3 is a great example – so heavy and sturdy.
And mode memory? It is like bicycle gears – you have to think ahead to lower the gear before stopping, if you don’t, it’s very hard to move. And somehow no one is complaining and saying “make auto first gear function when stopping”
pipa
Hi Mocarny,
first of all: thank you very much for this review. i realy enjoyed it.
second: i have not bought the light because of this particular review, zero complain or offense
i just put my “i don’t like the UI” post here because the title of your post “inspired” me to do so
Agree on the Convoy is a great brand and builds great lights.
Agree on the Anduril versus “easy to use UI”. For most of my lights i prefer an easy UI
But this (S12 and other recent Convoys) UI isn’t easy for me.
4 modes: great
Simple UI: great
I also like the stock Mode Spacing
But i like to configure (once) Mode Memory +Off+/On and Mode Sequence +Down+/Up to my taste.
Biscotti also allows choosing from different Mode Groups. Not a must for me, but i prefer even 3 Modes over 4 Modes
What i don’t like is starting somewhere in the Mode Sequence were i ended up last time (and i don’t remember) or accidentally ended up (some seconds/minutes before)
It makes me advance all modes until i am sure i am in Turbo or High (and this is what i very much dislike)
1. Turbo because i want Max Output: Now
2. High because i like to use it longer but at max sustainable Output
Mocarny
Mocarny's picture
Thank you Smile
I agree. It would be nice to have ability to turn mode memory on and off. I like mode memory, so it’s ok for me, but I understand there are lots of people that don’t like it.
Maybe something will change in the future… My personal best would be: one group 4 modes with memory on, and after e.g 5 clicks, other modes group, 3 modes with memory off.
wacki
Last seen: 6 months 1 week ago
How does the LVP work? Does it shut down or just give you a single “blip”? If it’s a single “blip” does it repeat? I’m always afraid I’ll miss those blips.
oweban
oweban's picture
Unsure about every mode, but I had it on mode 3 (30% I think?) a few nights ago; it flashes once every 5 seconds or so. At least that’s what it felt like Smile
Mocarny
Mocarny's picture
Confirmed, on every mode it flashes once every 5s for some time, then it shuts down. So even if you somehow miss that annoying blinks, don’t worry – it will turn off anyway. At…2.9V? Or something like that.
extremesquared
Last seen: 9 months 1 day ago
It’s too bad all the reviews of ultra-warm lights have usage pics from urban/forest areas. The 2700k s12 is my new favorite non-headlamp light for rocky/sandy desert and canyon hiking.
Mocarny
Mocarny's picture
I don’t have 2700K version. But canyon… You may see some light canyons in my future thrower reviews Wink
hasddie293
Dude, am I the only one who see there added led option on Convoy S12:
LH351D 5000K
LH351D 5700K
WOW! Amazing…
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Blggg
Last seen: 7 hours 54 min ago
Ordered this with LH351D 5000K some ten days ago. Hope it’ll be good.
