Expanded Phone Battery?
5 posts / 0 new
Bright_Mike
Last seen: 2 years 1 month ago
My phone battery has expanded, time to recycle or can I still use it? Concerned about safety.
I’ve had it about a year, off brand (ombar) since I couldn’t find known OEM for my old phone. Replacement came already.
Battery suggestions for an S5 welcome. OEM great if possible.
BlueSwordM
BlueSwordM's picture
Last seen: 2 weeks 3 days ago
Time to recycle it.
snakebite
snakebite's picture
Last seen: 2 days 9 hours ago
discharge then recycle.
flydiver
Last seen: 6 hours 27 sec ago
Do you feel lucky? Evil
I’ve got one for my camera right now. It is now a tight fit into a very limited slot. So, the slot alone may dictate when to stop.
It’s also lost half it’s capacity. I’m ‘semi’…comfortable with this scenario as this will happen to lipo batteries for RC flying. You watch them carefully, and decide based on experience (which is often bad experience) when to quit playing Russian roulette.
To Air is Human, to Respire….Divine.
Barkuti
Barkuti's picture
Last seen: 19 hours 54 min ago
NOHON batteries are of top quality, bought many already. Depending on model they may be even better than genuine.
For an S5: https://www.aliexpress.com/item/32747240635.html
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your spirit or soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
