Thermal properties of metals at a glance
10 posts / 0 new
pinkpanda3310
pinkpanda3310's picture
Last seen: 3 days 20 hours ago
Like a true flashaholic i’ve been interested in the different thermal properties of the metals used in lights these days. I understand most people have come to the conclusion copper is best followed by aluminium and brass then just about everything else. But I haven’t found an easy to read at a glance comparison between the commonly used metals. When comparing to copper even brass looks poor. But which grade of brass or copper. Some thermal characteristics can change quite a bit when alloyed with other metals.
Half the problem is I don’t actually know which grades of metal are used. I suspect 6061 aluminium, C101 copper, 6al-4v titanium, 316 stainless and brass …???…
So after some googling I put together this graph to capture at a glance the difference between the thermal properties of some common metals. If you see an error then you’ll know it’s because I just googled it. The only surprise to me is ti and ss are as bad as each other, for some reason I thought ti was marginally better than ss. Copper also looks to be a solid performer no matter the grade.
Aluminium
1000 – 230 W/m-K
5052 – 138 W/m*K
6061 – 151-201 W/m-K
6063 – 201-218 W/m*K
7075 – 130 W/m-K
Copper
C101 (99.9%) – 391 W/m-K
C106 (standard commercial grade) – 391 W/m-K
C110 (99.99%) – 390 W/m-K
Titanium
6al-4v (grade 5) – 7 W/m-K
all grades are poor – 7-22 W/m-K
Brass
C360 – 115 W/m-K
73/30 – 120 W/m-K
Stainless steel
316 – 16 W/m-K
304 – 16 W/m-K
I remember reading a thread a few years ago of somebody testing the thermal aspects of al vs cu. From memory the al took slightly longer to (heat) soak, was only a couple degrees hotter but maintained that small difference until the temperature of the heat source was changed. I don’t actually remember reading it but I suspect the al cooled faster than the copper. My guess is it did because the lighter density of al does not ‘hold’ as much heat as copper. When a hand warmer becomes a hand burner I want it to cool as fast as possible when it’s turned off.
Of course, the thermal properties of a light is only one facet of the many aspects of a light. I’m not a big fan of copper host lights but I am a big fan of dtp copper mcpcb’s. A copper host is not the best choice when using a brass pill or regular mcpcb.
Anyway I hope someone else finds this interesting. Copper reigns king, aluminium is good, everything else…. meh. For reference here’s another related table I found it shows even more metals – https://www.engineersedge.com/properties_of_metals.htm
KnHawke
KnHawke's picture
Good write up! Thumbs Up
These be the more common materials used, the more exotic alloys, like CuSil or just Silver, Artificial Diamond Wafer and Graphene, the wm*K starts shooting up.
One of these days, someone is gonna figure out how to use heatpipes within some of the larger light heads to further dissipate the heat these ever more powerful LEDs and drivers are cranking out. (Not like the Imalet MS18, they just used a bog standard cpu heatsink in there somehow)
kennybobby
kennybobby's picture
Last seen: 2 hours 31 min ago
The thermal conductivity is similar to electrical conductivity in that silver is the best conductor, followed by copper, then gold.
But the property of Heat Capacity or Specific Heat relates the amount of energy that can be absorbed to the temperature change that will be experienced. Magnesium has the highest HC, but aluminum 6061 is more commonly available and makes the best heatsink or housing. It can absorb a huge amount of energy before “heating” up to the touch, then it cools quickest when the light is turned off.
Copper transfers heat better than aluminum, just like it has lower resistance in wire. But once the energy has been absorbed and the temperature goes up, then it will stay there a long time (slower to cool down) due to the lower heat capacity.
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
amishbill
amishbill's picture
Last seen: 1 year 4 months ago
Darn. I have been looking at a Brass light (because I’m not fond of copper patina) because I though it would be closer to copper. Being worse than Aluminum was not what I expected.
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
Skylight
Skylight's picture
Last seen: 9 hours 45 min ago
Thank you for the list of metals. Didn’t know that titanium and stainless steel are that awfully bad thermal performers. Only 5-10% of aluminium! Ughh
Photonica
Photonica's picture
We’re thinking small, boys. I want Synthetic Diamond:
Quote:
To my knowledge, silver is the best conductor of both heat and electricity among metals with a thermal conduction value of about 430 W/(mK). Gold and copper both come respectably close to silver, and with Copper being significantly less costly it is often chosen over silver in many applications.
However, that’s just among metals. Diamond is actually a much better heat conductor than silver, around 5 times better for an average diamond. Scientists have also made super pure diamonds that can easily be up to 5 times better than regular diamonds.
Also, there is a Table here.
More Exotic:
Quote:
Diamond is the most highly prized of gemstones. But, beyond its brilliance and beauty in jewelry, it has many other remarkable properties. Along with its carbon cousins graphite and graphene, diamond is the best thermal conductor around room temperature, having thermal conductivity of more than 2,000 watts per meter per Kelvin, which is five times higher than the best metals such as copper. Currently, diamond is widely used to help remove heat from computer chips and other electronic devices. Unfortunately, diamond is rare and expensive, and high quality synthetic diamond is difficult and costly to produce. This has spurred a search for new materials with ultra-high thermal conductivities, but little progress has been made in recent years.
The high thermal conductivity of diamond is well understood, resulting from the lightness of the constituent carbon atoms and the stiff chemical bonds between them, according to co-author David Broido, a professor of physics at Boston College. On the other hand, boron arsenide was not expected to be a particularly good thermal conductor and in fact had been estimated – using conventional evaluation criteria – to have a thermal conductivity 10 times smaller than diamond.
The team found the calculated thermal conductivity of cubic boron arsenide is remarkably high, more than 2000 Watts per meter per Kelvin at room temperature and exceeding that of diamond at higher temperatures, according to Broido and co-authors Tom Reinecke, senior scientist at the Naval Research Laboratory, and Lucas Lindsay, a post-doctoral researcher at NRL who earned his doctorate at BC.
More Photons!
Lexel
Lexel's picture
Last seen: 1 year 3 weeks ago
More exotic wont pass ROHS, as its a toxic compound
Moissanite diamonds can be produced cheap with similar properties to pure diamonds
middle age man
Last seen: 1 day 6 hours ago
Sounds like a Cu head would double best as a hand warmer for winter walks etc…
pinkpanda3310
Yes, it relates to the total amount of energy transfer but not the speed at which it can happen. The speed it transfers is measured by thermal resistance.
If you ever come across a diamond, silver or gold flashlight please show us Wink
Once the light is turned off it will stay warmer for longer Cool
Agro
Agro's picture
Last seen: 15 sec ago
Please note that thermal conductivity is one of 2 big properties. The other is specific heat capacity i.e. how fast does it heat up.
You already noted that:
There are 2 kinds of specific heat capacity; the most common is gravimetric i.e. “how much heat does it take to up the temperature of 1 gram of substance by 1 K”. For us the most interesting is volumetric i.e. “how much heat does it take to up the temperature of 1 m³ of substance by 1 K” though both matter. Here heavier materials (like copper) have an edge.
Heat capacity, like conductivity, depends a lot on alloy. From my old notes:
Regular alu 6061 has thermal conductivity of 150 K/W and heat capacity of 2.42 J/mm³K. 6063 has 200 K/W and nearly the same 2.43 J/mm³K. Copper has 400 K/W with 3.44 J/mm³K. 7068 which I think is the overall best flashlight alu for being much tougher than 7075 with great thermals – has 190 K/W with 3 J/mm³K.
