Astrolux EC01 Driver
6 posts / 0 new
80T
80T's picture
Last seen: 16 sec ago
So.. since nobody has so far pulled out the driver off an Astrolux EC01 as far as I could find, I've took mine out and took some pics (the curiosity was killing me.. )
It appears to be a Boost driver.. (?) +1 7135 and runs on a Tiny85 MCU the FET is a QN3109 and the Boost IC seems to be a PL7203, which I cannot find much info about..
Either this, or the PL7203 is a.. [quote] "2K x 9 dual-port FIFO memory" (which I don't really find a purpose for in this driver) and the driver is a FET +1 7135..
Anyways, I'll leave the.. "reverse en.. *ahem, guessing" for the more knowledgeable veterans around:
Cheers!
gchart
gchart's picture
Last seen: 7 min 41 sec ago
Thanks for the pics. But since this light uses a 3V LED, I doubt it’s a boost driver. That coil might be paired with the PL7203 for the charging circuit?
bidas
Last seen: 4 weeks 1 day ago
The PL7203 is a battery charging ic: datasheet
The 2.2uH inductor is for that circuit so no boost Wink
80T
80T's picture
Ah.. makes much more sense now..
Thanks for the replies, good observation Smile
Cheers!
SammysHP
SammysHP's picture
Last seen: 3 min 48 sec ago
This driver is also used in the Wurkkos TS30S.
d_t_a
Last seen: 7 hours 54 min ago
I wonder if the Astrolux EC03 also uses this similar driver?
(Astrolux EC01, EC03 and Wurkkos TS30S are supposedly also manufactured by Sofirn)
