I've seen djozz take the phosphor off one on YT and everyone else is slicing them, are these impossible to dedome or are they difficult to get clean like Nichia ones? If I did slice them would a partial dedome look ugly on the beam? I'm used to taking it off, my nichia was hot dedomed, ... Poorly
I tried hot dedoming and it did not work one time. Perhaps, like Nichia’s, the phosfor is a silicone mix so there is no splittable boundary between silicone and phosfor.
But given that when sliced to right on top of the phosfor I get 800 Kelvin CCT drop, the effect is pretty close to a full dedome like the old Cree’s.
II would prefer to dedome just because I'm used to it. Would it matter if I just did a partial slicing then? I'm a bit worried about messing it up. Is the UV part the same as if I bought a UV? If so I have nothing to lose!
I have accidental done a too much heat dedome before but the phosfor came off with the dome.
Slicing the LH351D is my preferred led of choice.
My favorite slice for tint is the 3500k UPP6 from Digikey. I ordered a few more just a few days ago. The sliced 4000k turns out pretty nice too.
Slicing makes a nicer beam in my opinion. You get a tighter better tint hotspot that doesn’t look like a TIR optic. The hotspot fades outward from the main cornea, no defined circle like with the dome on.
To prevent too much heat, what temp should it be? I'd love to justify a laser/UV heat thermometer, they are only $8 on Ali. I'll try slicing too, I want a bootleg Rosy nichia since I don't have one anymore :(
Good to know that it's not impossible, I haven't heard anyone say it was possible and everyone was slicing theirs
No it does not. Not the common way how I (we) dedomed Cree leds in the past. It may work fine under a defined set of circumstances unknown to me (please explain, maybe with a video? ), but without further information it does not “work fine”.
I ruined it trying to dedome it. Is this light dangerous, in terms of uv? I have attached pics of it and beam shots, it's very ugly and 2 toned now. There is a pic with a rock and uv light versus mine as well not sure how to check how UV is is. I need a sharper razor. The pictures are in backwards order, the first is the UV lit light. Am I the first to dedome a warm light and get a cool white light?
CRI is gone. Maybe I haven't used a cool white in a while but I'm trying to decide if I like it or not. It looks so weird, I don't think I like it but I can't stop looking or trying it out. If I continue cutting it, will it turn into a UV light? Any way to remove the last of the phosphor or whatever is left?
Thanks so much! Is there anything you can suggest to do with this ruined LED? Can I make it "more UV" or lower it but cutting it, or is this as low as the UV goes?
Hey, so I got a Wurkkos WK30 with LH351D, red led, UV, 3 in 1.
I was going to find a blue filter to cover the LH351D. I already have the Convoy S2+ but I rather have a 3 in 1.
