✌ FREEME - ASTROLUX MF05 SBT90.2 7000lm 3000m+ Thrower Searchlight
551 posts / 0 new
grin
3.5km
Xandre
Xandre's picture
Last seen: 29 min 20 sec ago
WoW Thumbs Up
Regards Xandre
freeme
freeme's picture
Last seen: 4 min 32 sec ago
Any more people need a new coupon for this?
prilo
prilo's picture
Last seen: 2 days 22 hours ago
Boss I need one coupon more,
freeme
freeme's picture
Done!
Eric's_thrower_...
Eric's_thrower_flashlights's picture
MF04 and MF05 comparison 3140 meters
Astrolux MF04 and MF05 comparison:
https://youtu.be/s67ZY8EAqpQ
Eric
grin
Took a bit of effort SN25 did the job.
Chinaheart
Chinaheart's picture
Last seen: 1 week 2 hours ago
interested
liteupmynite
Last seen: 3 weeks 11 hours ago
UPDATE:
The replacement fan handle for my Astrolux MF05 from BangGood finally arrived after nearly 2 months of back and forth with BangGood customer services. However, the fan handle slide that’s slides into the slot on the light was damaged. I had to file off the damage portion of the slide to make it fit. And the tail cap spring was detached. I was able to reattach it.
Quality control, Quality control, Quality control!!!
All good now. Fan works: 3 quick clicks on, 2 quick clicks to change modes, 1 long click to turn off.
For those of you who have experienced that same issue, here's a video that I used to convince BangGood and Astrolux there was an issue: https://www.youtube.com/watch?v=dtu9nRiODSk
JasonWW
JasonWW's picture
Last seen: 19 hours 9 min ago
Dzeric wrote:
I could’ve sworn I bought 8×30Q (15A max), turns out I bought 35E (8A max).
Just a note, those are not max ratings, those are continuous ratings.
jp9mm
Last seen: 1 week 19 hours ago
I have a windmill 1 mile away. Visible during day but can’t quite see it at night with mf04. Maybe time to try with binoculars
Eric's_thrower_...
The MF04 should be able to light up something a mile away. I shined mine on a water tower at that distance and I could see it getting lit up.
If you have a tripod, aim the light at the windmill, and then step to the side so the beam doesn’t block your view. Then use binoculars or a camera with a long exposure to view it like I did for my water tower photos from two miles away.
Eric
jp9mm
The MF04 should be able to light up something a mile away, unless the object is dark or there is too much light nearby. If you have a tripod, aim the light at the windmill, and then step to the side so the beam doesn’t block your view. Then use binoculars or a camera with a long exposure to view it like I did for my water tower photos from two miles away.
I will have to take out the binos and try again,I didn’t use a tripod either. the windmill is white colored but may be less visible depending on how its facing . Also wasn’t sure how much humidity would affect my ability to see it.
I’ve tried it at 50%, just thought it would be easier.
Theodore41
Last seen: 2 days 13 hours ago
I ordered the light two days ago,and it is on its way to me now,so I ask what batteries should I use?
I think the old good 30Qs for the 18650s,but I don’t know which of the 21700 one to buy.
I ask,because the price range is huge,ie in NKON.nl. store,I see the price is between €3.45-€19.95.
Any suggestions please?
JasonWW
JasonWW's picture
Of what I see in 21700, the best value in a high capacity cell is:
https://eu.nkon.nl/samsung-inr21700-50e.html
The fan battery does not need to be high drain.
_______________________
If you ever need high drain 21700 cells, these are some good ones.
https://eu.nkon.nl/molicel-21700a-4200mah-30a.html
https://eu.nkon.nl/samsung-inr21700-40t-4000mah-30a.html
Super high drain would be 30T
https://eu.nkon.nl/samsung-inr21700-30t-3000mah-35a.html
Theodore41
Thank you very much,but I see they are flat top.Can I use them as a fan battery?
JasonWW
JasonWW's picture
From what I remember, the fan uses a spring on both ends of the battery tube so a flat top should be fine.
Theodore41
Thx again.I ordered all from NKON.nl.
zoulas
zoulas's picture
Last seen: 5 hours 59 min ago
This will be < $100 for the holidays.
CNCman
CNCman's picture
Last seen: 6 hours 17 min ago
I like the reflector Cool
But its too expensive for my budget light wallet. Silly
Theodore41
I bought this because I could find a 24h flash sale of 55% off.So I payed only € 273.00 all included. Smile
freeme
freeme's picture
17 left.
SuperMassiveBla...
Of course you would notice the difference. That’s a nice increase, maybe if it wasent as much of an increase. When you start looking at things further away is when that increase is really noticed…
The Phial of Galadriel
SuperMassiveBla...
Hey guys quick question. I just got my astrolux mf05 the other day and the little tiny lens inside the flashlight that goes over the led came off. Also the black plastic part that goes down in the flashlight around the led also came off right away: I tested it out like this tho and the flashlight seems to work better actually. The dot and the beam it throws is tighter and closer to a perfect looking circle. I’m actually very happy with how it affected it but kind of bummed out that it happened literally right away. What is that little lens for, it’s for ir light right or… also will the flashlight be fine to run without both of those things? Also how do I use the url thing to post pictures? One more thing, has anyone else noticed these things and does anyone else have problems with there beam and dot not being a perfect circle. I’m ocd and it’s absolutely vexing lol. Tho with the little lens and the black plastic protector around the LED off the beam and dot is nearly a perfect circle ⭕️ and just seems quite a bit nicer. I was like what the heck why is this Happening then tested it out and was like damn holy shit ok I’ll take it lol. Last question… So I know you can run the flashlight with just four batteries but if you use all eight is there any benefit to that or like will it last longer and turbo motor any of the molds?
Scallywag
Scallywag's picture
Last seen: 5 hours 38 min ago
So, the window is protective. Removing it manually increases performance somewhat, however the lens protects the LED. Also the removal process could damage the LED if you’re not careful (and the darned things are expensive).
I’m not sure what the black plastic thing you’re referring to is.
As far as posting images, feel free to reference this post
SuperMassiveBla...
Right I thought it increased performance decently and made the beam better. I didn’t take it off as I was unscrewing the top of the flashlight where the lens is it literally flopped off. And that part I’m taking about it right where the led is there is a black protective part around the led. Which slightly raises the reflective part of the flashlight. That black plastic part litterally wasn’t even attached and just fell off. But in doing so that is what actually made the beam look better. It made the reflector move slightly closer to the flashlight case itself cause the plastic part is a cm or so in thickness maybe more. That’s what made the beam a lot better looking. Again I didn’t take it off it just fell off. I contacted the company I got it from hopefully they can help: honestly I like it more like this but at the same time I don’t want it to ruin the flashlight. I’ll post a picture when I figure it out
JasonWW
JasonWW's picture
You need to host the picture on a separate website, like imgur.com, and then you put a link here.
Some people like to remove that glass lens for a better beam and more output. So it’s no big deal that yours fell off. (It’s strange that it did as I’ve never heard of it falling off on its own) Just remove it so it doesn’t bang around scratching the reflector or damaging the led.
SuperMassiveBla...
:https://imgur.com/gallery/d7VBHIl
I’m posting the image on Imgur and copying and pasting that link to it and it shows up when I’m trying to put it I the post but when I post it it doesn’t show up.
JasonWW
JasonWW's picture
That is not the correct image link. A gallery link will not work. You want to open each picture and get it’s link.
I find the phone app for imgur is a lot easier to use.
I’ll post your pics here.
JasonWW
JasonWW's picture
The big black piece is a centering ring. If the reflector pushes down real hard on the mcpcb it could cause a short and damage the light. I would keep it installed.
