Ampsplus 18650 3000mAh (Black) 2020
Official specifications:
Battery Size: 18.75mm x 68.80mm
Nominal Voltage: 3.70V
Nominal Capacity: 3000mAh
Rated Capacity: 2950mAh
Charging Method: CC/CV 4.20V ±0.05V
Discharge Voltage: 2.50V (Average Cut Off)
Operating Temperature: –20 ° to 60 °C
Standard Charging Current CC: 1000mA
Rapid Charging Current: 3A
Continuous Discharge Current: 15A
Protection Circuit Cut-Off: 15A
Max. Discharge without 80°C Temp. Cut-Off: 30A
Weight: 49gr. ± 0.5gr
Colour: Black, Silver , Purple
Protection Circuit Board / PCB: Yes, Protected
Gold Plated PCB
Version : Button Top
This is a protected high current battery, this limits the high current aspect of the batteries significant.
The two cells match nicely and handle current up to about 10A where the protection kicks in.
The battery may deliver 15A peak current, but as usual with protection the trip limit varies with time the current is on.
Conclusion
It is a good battery, but with the protection the maximum continuous current is about 10A. The protection do also provide over discharge and charge protection (They always do).
Notes and links
The batteries was supplied by Ampsplus for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
