[Rumor] new 40700 cell size
92 posts / 0 new
Lexel
Lexel's picture
Problem with cells of that output power would be you can’t use springs anymore
djozz
djozz's picture
Last seen: 36 min 49 sec ago
Leaf springs are an option but they have less travel.
Serifus
Last seen: 9 months 2 weeks ago
5 sets of double springs might handle that shock load, and amperage, but i dont think that there will be anyone building protection circuits for a 40mm cell. Honestly i am more interested in a 4×20700 lt1 max with 20ah of battery or some extra fat 4×20700 soda can lights. Most scenarios that would permit 40mm cells are going to require inbuilt charging, cars and flashlights and other. Also im genuinely curious as to if the maxwell aquisition will give many fruits of development due to ev drain chaeacteristics being the high amperage pulsing to energise motor windings
EasyB
Last seen: 9 hours 51 min ago
Bypassed springs should be fine though.
Hugh Johnson
Hugh Johnson's picture
Last seen: 2 weeks 2 days ago
samgalax wrote:
Think in the price of those 40700…
50$ each???
It would likely be cheaper. And you would only need one. Per light.
Barkuti
Barkuti's picture
Last seen: 15 hours 8 min ago
Seriously, what's the point? Used many search engines, and nothing but this.
In all honesty, if the point is to build up subtle (mental, emotional) energy around this to see if Tesla Big Smile gets the idea, why 40700? Most people here don't really care about a newer “40700” format, or don't know. I do know what I want, and I don't care.
Most people here would prefer and love to see improvements on current formats like 26650/26700 or 32650/32700. Concerning flashlights, a completely new cell format like 40700 means you have to build up everything around a new format, again, just for the vagary of someone else.
So then, how about spreading some other rumour like “new Power Long Battery 26650 cell, 6.5 Ah and 5C continuous discharge rate”. It could also be possible and very welcome. They seem to be quite focused on LiFePO4, though.
samgalax wrote:
Think in the price of those 40700...
50$ each???
$50? LoL! No way. The actual price of cells is a lot lower than what you usually see, more than probably. You can get Lishen 21700 cells for less than $3 a piece in AliExpress. At ≈3.628 times their volume, that's just a bit above $10 for an ordinary 40700, and probably up to $30 - 35 for higher capacity and power output cells.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
Agro
Agro's picture
Last seen: 1 min 10 sec ago
1. Not every light needs to be a hot rod. F.e. smaller and lighter LT1 with even more capacity would be a good thing.
2. I don’t think this is the case. With a cell this heavy you need very thick springs anyway. With seen double springs doing 25A. Now double thickness of each wire – that can do 100A. Is it not enough?
Barkuti wrote:
Seriously, what’s the point? Used many search engines, and nothing but this.
In all honesty, if the point is to build up subtle (mental, emotional) energy around this to see if Tesla Big Smile gets the idea, why 40700? Most people here don’t really care about a newer “40700” format, or don’t know. I do know what I want, and I don’t care.
50$ each???
$50? LoL! No way. The actual price of cells is a lot lower than what you usually see, more than probably. You can get Lishen 21700 cells for less than $3 a piece in AliExpress. At ≈3.628 times their volume, that’s just a bit above $10 for an ordinary 40700, and probably up to $30 – 35 for higher capacity and power output cells.
Personally I would also prefer improvements to the existing standards rather than new ones. Though 40700 seems like a nice size, larger than 32650 enough to create its own niche. And since I’m not fond of the multi-cell lights I’d be very glad to see improvements in this area.
Though I admit, the thought of spending $$$ to replace my largest (read: the most expensive) lights is not nice. Wink
And I agree, the rumor is quite far fetched and I don’t look forward to seeing it implemented. If it shows up – it shows up. If it doesn’t – it doesn’t.
djozz
djozz's picture
I think that I’d love a 40700 size cell in a small fatty flashlight with immense output or immense runtime at low modes, makes a nice lantern too.
alpg88
Last seen: 4 days 12 hours ago
as far as springs, sure, they’ll just have to be a bit ungraded. this is my 10A switch for 200w hotwire, switch was built by matt from ASF.
snakebite
snakebite's picture
certainly wont be anything new.
m cell
thefreeman
thefreeman's picture
Last seen: 11 min 19 sec ago
New pics seem to confirm the new format
They say that it is double the diameter of current Tesla cells (21700)
thefreeman
Drew this quickly with 42mm diameter :
Without play :
3×18650 : 38.8mm
4×18650 : 43.5mm
3×21700 : 45.4mm
4×21700 : 50.7mm
Skylight
Skylight's picture
Last seen: 1 hour 1 min ago
I have found a 40900 cell on Taobao: https://item.taobao.com/item.htm?spm=a1z10.3-c-s.w4002-21513148700.70.66...
It is pretty inefficient, though, with only 5.5Ah. But it has only 2 milliohms internal resistance. Seems to be made for car starters.
Agro
Agro's picture
Interesting. This is a huge news if true. Fortunately we’re likely to learn whether it is in just a week. So I’m waiting patiently.
moderator007
moderator007's picture
Last seen: 6 hours 25 min ago
Similar sized batteries in LifePO4 chemistry that where available over a year ago.
I mentioned them here.
http://budgetlightforum.com/node/69245
idahofarmer
Last seen: 6 days 7 hours ago
Its a 5498 cell, 10x the energy of a 21700. Floats in antifreeze to warm and cool cell.
One of these cells in the blf-lt1 would give a 2 month runtime.
https://www.youtube.com./watch?time_continue=5&v=QQY2vYhysBY&feature=emb...
Agro
Agro's picture
moderator007 wrote:
Similar sized batteries in LifePO4 chemistry that where available over a year ago. I mentioned them here. http://budgetlightforum.com/node/69245
The difference is that:
  • they are LiFePo4
  • their energy density is terrible when you compare with the good 18650 and 21700 cells
  • they are being made by small manufacturers which greatly reduces the chances of being adopted by flashlight makers
idahofarmer
They have 10x a 21700 energy. Tesla will use battery pack 1/10th the current size. How is that terrible density? Not understanding ?????
It has a catalyst electrode and drops into a pack. Levels of magnitude better then 21700. New teslas built with this 5498 cell will cost msrp 29k and have 300+ mile range.
I will buy one and charge with my solar array and drive for free.
  • they are LiFePo4
Agro
Agro's picture
If it’s 54 mm diameter, a host will need a handle to be comfortable. Sad
Agro
Agro's picture
  • they are LiFePo4
I was replying to an earlier post.
I already added a quotation to make it clear to others.
idahofarmer
You must have small hands. I was hoping for a headlamp. Party
thefreeman
It seems that the number 54 comes from “FX054” marking on the can, that sounds like a very wild guess if you ask me, granted it looks bigger than 40700 unless those are small hands.
idahofarmer
The bad news is now what will happen to the 21700?
idahofarmer
Watch the video…………
thefreeman
That comes from the twitter guy cited in the video, unless I missed something else (video is such an annoying format, just write an article).
Andrew_Debbie
Last seen: 1 week 3 days ago
And there are rumours the new batteries will be LFP.
https://cleantechnica.com/2020/09/16/tesla-battery-day-has-elon-musk-alr...
idahofarmer
I hope they make packs available to solar off grid users. It would be awesome to have a 100kw pack.
SKV89
Last seen: 6 hours 18 min ago
Seriously exciting! But if it is manufactured in-house by Tesla, will it ever be sold in the after market?
Agro
Agro's picture
Maybe no…but it starts the same as 21700. These cells were intended to be used by Tesla in their vehicles period.
Then they landed nearly everywhere…
JaredM
JaredM's picture
Last seen: 4 hours 53 min ago
I don’t think the pack is going to be 1/10 the volume. There will likely be some packing efficiency improvements with the larger cell, but overall volume should remain similar. A 10x reduction in volume would require other worldly improvements in active material specific energy.
The point for them is $$ first. Fewer cells in an architecture with shared components will save time and money in production. I’m not qualified to even guess how much that may be, but I can say pretty confidently the energy density of the cell is not 10x current values.
https://fundrazr.com/osturaband
No affiliation, just a fan.
