There’s a XP-L HD built into the Utorch S1 mini. Color of the NW-model is pretty nice but beam has rings. In contrast, the Klarus Mi1C (non-HCRI version) comes with the same lens but with a XP-L Hi, no rings.
I imagine a lens produces the cleanest beam with a small, domeless LED. Is my imagination in compliance with the theory? If yes, the smallest LED I have is the SST-20 (I have a couple of 4000K LEDs), but it has a dome. Now, if I’m right thus far, would you think dedoming it would give an optimal beam? Or is a XP-L Hi better? Other non-CW non-lousy-CRI options?
The rings might be coming from a part of the flashlight like the bezel, rather than whether it is a dome vs domeless LED.
You can usually track down the source of the rings by aligning your eye with the ring(s) and looking into the flashlight (in a low mode) to see where the light is coming from.
The outer ring comes from the bezel. There’s a dark center spot surrounded by a bright ring, then a less bright radial area. This must come from the LED.
I’d take a picture, but the artifacts are best visible only when moving the beam.
It’s not that disturbing, but since the Klarus does better with the same lens, I thought I could do something about it.
However, my Warm LEDs see very little actual use. They are best for full dark situations, such as camping (which I have not been doing), or late night walks to the bathroom (but I dont really need it, due to streetlight coming in the window at night).
the 4500k 219b is more practical for most of my uses
I really like the aspheric beam, though I agree it is not perfect (especially the outside edge), it is very useful for close work. I do agree that the bezel produces its own artifact… I used a black marker to eliminate its reflections.
I had the Klarus, too, and soon will get an OTR i3. Can’t resist those lights. Agreed, NW is most of the time a comfortable color temperature. WW lights are candles in my houshold.
The i3 is a zoomie, unlike the Klarus flashlight!
On it I am using a Samsung LH351D led, and I “blackened” the gasket, the metal gasket and even some parts on the edge of the optic/lens.
Also, the Samsung LH351D is great for flood, but when completely focused, at a certain distance and against a white wall, you can see other colours in the die.
I guess maybe a Luxen V2 (3000K) would be good a good option for these lights!
I ordered it with the XM-L2 5C. Hope I can stand it as it is, but won’t hestitate to do something about it if not
Edit: Just tried SST-20, shaved SST-20 and Samsung in the Utorch . Reverted it to the nice NW XP-L HD. The SST-20 was interesting. Yellow/purpel rings! I’ll leave it now as it is.
