Super-Visible Beam/Vertical Column of Light Project
61 posts / 0 new
Dr scott Diabol...
Dr scott Diabolical - Evil Genius's picture
Last seen: 1 year 2 weeks ago
Hello everyone,
I’m a noob but have been lurking for a while. I’d like your advice on a project I’m planning. I’m sure others have more experience with this than me. What I want is a vertical column of visible light, i.e. a super-visible beam. It needs to be immediately noticeable in high ambient light conditions since it would be included in a Christmas lights show. And, there’s a street light within 150’ (50m). It needs to be most noticeable at an altitude of 27 ft to 250 ft above ground level. Is something like this possible with a budget around $200 US? If so, what’s the best strategy considering the budget?
Goal: Most noticeable and visible beam possible for $200 or less
Size: N/A, fixed installation, could be the size of an arc-light, who cares
Weight: N/A, fixed installation
Beam width: ideally 5 degrees
Available Power Supply: 10-20 amps 120vac, or 30 amps 220vac, 60hz (I have both available to drive power supplies & converters/drivers, etc)
Throw: not really important since this will be mounted vertically.
Color: “white” …whatever is the most visible
Distortion/Rainbows: doesn’t matter
Heat sinking: not a problem, I can build a giant one the size of a trash can and add a 400 cfm bathroom “fart-fan” if necessary.
I’ve been looking at several projects. Both the “ dollar store trash can” and the “speaker box” fresnel lens projects look interesting. Would an inexpensive fresnel sheet-lens and multiple “100w” COBs (possibly combined with 60-degree reflector-lens setups) get me where I need to be? As long as I stay within budget, this project could have as many individual “elements” as the $$$ will allow. And they could be grouped together, or set at any spacing that produces the overall effect.
Would some other strategy work better for the $$$ ?
Thoughts and recommendations welcomed. Thanks!
ReManG
Have you looked into just building a carbon arc torch for a light source?
Failing that, the fresnel lens idea with the cob emitter s should do great. The light visibility will have to do with some of the reflectivity in the air, a fog machine may help with that at lower levels. Good luck and let us know what you come up with.
As always, we will want beamshots….
Dr scott Diabol...
OK, I’ve been digging deeper into this rabbit hole…
As awesome as LEDs are, I’ve determined that they may not be the best solution for this project. In terms of budget, I think I can get a lot closer to the goal by using a metal halide HID lamp and an 18” parabolic reflector. I found a project over on CPF where the guy made his own 24” reflector from foam & fiberglass. It was lined with chrome tape from an auto parts store. So, not exactly the best reflector in terms of optics or efficiency. Yet he was getting the type of beam results I want with a 100-watt HID. And his 400-watt HID was what I’m looking for in terms of beam visibility. The 400-watt MH-HID lamps I’ve seen so far are rated at about 36,000 lumens. And those are brand-name lamps like Sylvania and Lithonia (and I personally know the engineer that used to head the photometric lab at Lithonia, so that’s probably an accurate rating and not “internet lumens”. 36,000 basic radiated lumens ain’t a bad start. And I can get that for about $100 shipped from 1000bulbs. (still comparison shopping though). Plus, better quality aluminum parabolic reflectors are now available for under $100 US. I found an 18” listed for around $60, which seemed to be the best deal for the money. NASA Searchlights uses 18” reflectors in their commercial rigs, so that’s probably enough for this project.
Now here’s where the fun begins. For a few dollars more (insert Clint Eastwood meme here), I could step up to a 1,000-watt MH-HID. That would put me in the $150 range for the lamp, ballast, base, and shipping. But it would get me around 110,000 base lumens! I could probably make a searchlight out of a trash can lid with that kind of power.
So, I may end up asking the MODs to move this thread over to the HID forum. But here’s what I’m thinking so far…
18” Edmund Scientific aluminum parabolic reflector
400-watt MH-HID lamp (or maybe 1kw ???)
custom-built enclosure and focal length/focusing rig
Some sort of shutter mechanism (probably made of steel to deal with the heat)
The shutter will be necessary because the effect I need is “instant on”, and that’s not possible with HIDs. The goal of the beam-effect is to punctuate the crescendo of the song that the Christmas lights will be choreographed to. When the song reaches the crescendo, what I want is BAM! INSTANT 1,000 FT TALL TOWER OF LIGHT! The effect will only need to be seen for about 10 seconds. Then it needs to be gone, because the song fades down and the lights will too.
OK, back down into the rabbit hole. Gotta explore the effect of arc length on beam width today.
azj
Last seen: 1 day 9 hours ago
You might have a look at what djozz is doing with his fresnel lens thrower build. That looks to be relatively cheap and portable…
One Bulb to rule them all,
One Bulb to blind them,
One Bulb to bring them all,
and put the darkness behind them
Dr scott Diabol...
Already following!
FYI:
I’ve decided to shut down this thread and possibly re-post in a different forum. In the last few days, I’ve gone down the rabbit hole on LightSward’s HID-based parabolic reflector spotlight projects over on CPF. They look very promising. I think MH HID will be the only way to get enough lumens to achieve my design goal within my budget.
Dr scott Diabol...
9 months later…..
I’m finally back after months of Halloween, Christmas, and IRL getting in the way. Regarding this project, HIDs are no longer an option. When my professional Lighting Engineer relatives reviewed my proposal, their response was “DON’T F$%^g DO THIS!!!!” HIDs do not play well with sketchy reflectors like the Edmund Scientific “salad bowls”. Any light that reflects back into the arc chamber can cause them to explode. In fact, HIDs don’t play nice at all. They’ve killed people. And when the correct PPE for changing a lamp involves body armor… yeah.
Soooo… round two: a lot more research and a few new projects to follow. I’ve been looking into LED-based solutions. Most notably Enderman’s Lightcanon project. Other than the Wavien collar, there’s no unobtanium in the design. He used an XP-G2 and a FasTTech 100mm aspherical lens https://www.fasttech.com/products/1606/10002523/1583700. His followup project used an Osram black flat and a better lens.
Since the Wavien is now basically unobtanium, I’m wondering what sort of result I’d get with a mildly overdriven Osram CSLNM1.TG (flat white), no collar, Intel heat sink, and the cheap FasTTech lens? Would there be enough visible beam to make building & bundling 5-10 of these together into an array worthwhile? Size is not a problem with this build, but cost is. I can save a few bucks by omitting the batteries and using either an off-line (120vac source) constant current driver, or a conventional driver and an off-line constant voltage power supply.
Enderman, Djozz, your thoughts?
Sunnysunsun
Sunnysunsun's picture
For beam visibility you need to put a lot of these modules side by side. Think 7+ in a hexagon shape like a E07
Do you have a C8+ with a flat white? Imagine holding 7 of them and seeing the beams in the air. They beam won’t be super bright but should still be something to behold.
wle
wle's picture
Last seen: 4 hours 39 min ago
one problem is, if the air is dry, and ‘too clean’, it is hard to see any visible light
it has to reflect off something to come back to the person on earth
usually that is dust or water vapor drops
green is the color the eye sees best, and yellow
so i would say green laser, but they are not very wide.
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Dr scott Diabol...
Sunnysunsun:
Yes. But instead of a 7-up TIR where the beam angle is 5-10 degrees each, I’m thinking 7 (or more) Enderman Lightcanons/Optofires https://budgetlightforum.com/node/55370 Something like this:
The problem with Enderman’s builds is that they both used a Wavien collar. According to Enderman’s posts, that boosts the Lm/Cd by 2-3x on an XP-G2 or Osram black flat. But Wavien collars are now pretty much unobtanium and were always $$$$. So, is there a way around that bottleneck using a more modern (yet affordable) led and reflector with a sufficient lm/cd? One that would still work with the cheese-grade Fasttech 100mm lens? https://www.fasttech.com/products/1606/10002523/1583700
We shall see.
A recoil design using a very large parabolic reflector would be a better idea. But all of the affordable reflectors (Edmund Scientific, kids toys, solar collectors, etc) have been tried and have failed. Bad optics = salad bowls. And for the price of a quality electroformed reflector ($2,000 US), I could just buy a used single-head SkyTrakker, or a big DMX moving-head and be done. But I don’t have that kind of cash. I have seen large glass reflectors listed on Ebay, but they’re still $$$$ and I haven’t seen anyone use one yet. And for me, that’s too much money to risk. here
I have already tried a cheap “page magnifier” fresnel lens like the ones used in COB projects on YouTube. Using a 300-watt halogen worklight as an emitter, I could focus the hotspot down to the size of the bulb itself. But I couldn’t columnate the beam or more importantly, see it. Made a great flooder and an ok thrower, but utterly failed as a beamer.
I also have an ADJ Pinspot II stage light. It’s got a “3-watt led” of some sort and uses both a TIR and a plano-convex lens. But it’s best beam angle is 6 degrees. On a very foggy night, I can see its beam for about 1000 ft (300 meters). But on a clear night, nothing. The beam is not columinated and is not intense enough. Makes a good thrower though… if you want to light a disco ball.
Dr scott Diabol...
wle:
Yep. And Colorado is a desert. Our relative humidity is often below 10%. We do have dust and smoke, but not usually in December. And counting on fog or a blizzard is cheating. Even a street light makes a beam in those conditions.
kennybobby
kennybobby's picture
Last seen: 4 days 2 hours ago
How about using some sealed beam headlights from an old car?
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
Dr scott Diabol...
!https://i.ebayimg.com/images/g/i5EAAOSwUPxdN1W5/s-l400.jpg!
I don’t think that would do it. Based on other projects I’ve seen, what I need is a super-tight columnated beam with the highest intensity I can get… times as many as I can squeeze into the budget. I know that a recoil-parabolic reflector design would be best. That’s what the Sperry/GE carbon arcs used. The problem there is cost. Every inexpensive large parabolic reflector project I’ve seen has failed because of the reflector optics. Pot lids, kid’s toys, solar cookers, satellite dishes, Edmund Scientific 12/18/24”, that thing LightSword made… they all have the columnating ability of… a pot lid. And car headlights are basically designed to spread a beam about 40’ (10m) with a throw of about 150’ (100m). Great for illuminating a road, but not great for a searchlight. Though I do appreciate the suggestion!
I’m looking for a throw of 3,000’+ (1km), with enough intensity that people can see the beam on a clear night. (Jamie wants big beam.) Enderman’s aspheric lens projects (Lightcanon, Optafire) achieved that throw. But not the intensity. They used 100mm and 120mm lenses respectively, which is big for a flashlight but tiny for a searchlight. However, the overall design was simple, effective, and inexpensive. The only piece of unobtanium was a Wavien collar, which concentrated the led intensity by 2.2x. But that was with an XP-G2 and an Osram black flat. LEDs have come a long way since then, and the Wavien may no longer be necessary. Likewise, since my goal is not max lux in the hotspot or max throw, I may be able to use a larger but less intense LED source that has higher overall lumens.
So here’s my plan as it stands:
1) Continue down the research rabbit hole for a bit, then compile the results and filter for the best combination of stock parts for use with the 100mm lens. (Did I mention I’m a data analyst by profession?)
2) Build one 100mm aspheric using those parts. Keep the costs and parts-count low and refine that design.
3) If its successful at a small scale, that becomes the basic unit for the large project. Then I can build more and just bundle them together into a giant modular array.
4) That would allow me to build additional elements as my budget and schedule allow, instead buying a single big expensive reflector and hoping I succeed.
5) And, ya know… a 2m diameter “flashlight” powered by a 4kw generator is portable, ain’t it? I’ll bet I can fit it on a 4’×8’ utility trailer.
Now I just need a cool name for this project…
Light-A-Ray? (Larry)?
Big Lumen F-er (BLF)?
Finger of God (ok, maybe I’ll save that one in case I ever have the budget for a Sperry carbon-arc)
Dr scott Diabol...
OK, parts are on order. Here we go…
I’m going to start with an Osram CSLNM1.TG and a 3 amp CC single-mode (100%) driver from Mountain Electronics. That seemed to offer the best combination of die size, intensity, and cost for a thrower. For power, I’ve got a Mean Well 3.3v 60 amp off-line power supply. The lens will be the Fasttech 100×30mm borosilicate plano-convex aspheric (cheez-grade, but less than $8 each). And the host will probably be a 4” (100mm) pvc sewer pipe. The only thing I haven’t decided on is the heat sink. I know a fan colled cpu heatsink would work. But a decent one is around $25. Which would mean $175 in heat sinks alone if I build the large array. I think a better option will be a custom-fabricated liquid cooling system. I can make that out of copper plumbing fittings and a fountain pump and just flood-cool the heat sink. But to start, I think I’m just going to use a big block of 6061-T6 Uh-LOOM-uh-num, because I have one out on the bench right now.
Should be fun. Stay tuned.
raccoon city
raccoon city's picture
Last seen: 3 min 7 sec ago
Location: Palm Desert CA ~ West Coast is the best coast
I hope you have fun here, Dr scott Diabolical - Evil Genius!
That is quite a username to type in.  ;)
114_milla
nottawhackjob
Last seen: 7 months 2 weeks ago
Well if all else fails there’s this open option…….. LOL
https://www.searchlightsofsandiego.com/rentals.html
I mean if ya really wanna attract extra attention to your unit first of course. Smile Shocked
PS. The FAQs are an interesting read.
“In many things in order to truly understand the small picture you have to understand the big picture first.”
True Color Rendition (TCR)/Simplified Definition: “On a scale of 1 to 10, with 10 being the highest rating, a TCR will equate to what true colors you see in sunlight vs the same object’s colors you see when illuminated with a flashlight. The closer the two are, the higher the TCR rating will be.”
The TCR Reference Standard is the Walmart Ozark Trail OT 50L , Model No. 6103.
It has a TCR rating of ‘10’. $1.00 including batteries.
Neurotoxin
Neurotoxin's picture
Last seen: 1 year 1 month ago
Well, this definitely sounds like an interesting build. Will this be able to light up low hanging clouds? I remember when I was little, I used to see pretty fat beams of light from VERY far away shining into the clouds. I would often see them around Christmas time, but I never got to see one in person so I don’t even know what they look like. Every time I saw one it would be literally at least a mile away. I’ve always wanted to do that, shine a very bright light into the clouds. I’m thinking your build will likely be able to light up clouds. Perhaps not to the extent of those batman signals I saw as a child, but definitely enough to eek out a chuckle in awe at least, since some of my flashlights are able to just barely light up the very low hanging ones. It helps that they’re white so they’re very reflective.
We will want beamshots of your build, by the way Smile
I just like shining my lights into the dark out of pure enjoyment and awe.
We've come far technologically and it's crazy to imagine what the future holds.
Dr scott Diabol...
raccoon city wrote:
I hope you have fun here, Dr scott Diabolical – Evil Genius!
114_milla
Yeah. but you’ll never confuse me with anyone else.
Dr scott Diabol...
I actually found a single-head 2kw SkyTrakker for sale for $1,795. They didn’t say what was wrong with it. Or, how much time the lamp had on it. But to me, $2k for a light is the same as $20k for a light. I ain’t got that much. So neither is possible right now. …still, there may come a point in my life when I become the custodian of a 60” Sperry carbon-arc. It could happen. I have a plan.
Dr scott Diabol...
That is the goal. Now to be fair, I can already light up “low hanging clouds” with my little 700mA pinspot stage light. But only when they’re 300 ft AGL (about 100m above ground) and it’s foggy. I want WAY MORE than that. I want you to see that beam in spite of the Christmas lights, and street lamps, and clear air. I DO want to draw attention. I do want people to see it from miles away.
Fortunately, I live in a little farm town in eastern Colorado (the uncool flat part, not the mountains). Folks out here would think a big light was “badass”. Also, I’m super-mindful of my neighbors. I only run the animated portion of my Christmas display once every 15 minutes, between dusk and 9:00 PM. I do not intend to become “that guy” with the too-big display that creates hassle, traffic, legal issues, etc. for his neighbors. When my Christmas display gets big enough, it’ll move to a commercial location and will be a drive-through experience. Likewise, I’m very mindful of aircraft. I live directly under one of the approach patterns to Denver Int’l Airport. When it’s in use, the searchlight will not be operated. Simple as that.
Neurotoxin
300 feet AGL? sounds more like fog to me Silly You’re lucky to have such low hanging clouds where you live! I’m talking about Cumulus clouds. The fluffy, white cottonballs that are several thousand feet up in the sky. (I think by definition, “low clouds” are anything under 6,500 feet) obviously with fog being excluded as that’s a ground level cloud. Anyway the point is I can already hit the very very low hanging cumulus clouds just barely, but I’d love to maybe build a big spotlight that could easily and very noticeably light up clouds several miles up in the sky. It sounds like what you’re building might be able to do that. The carbon arc really is a marvel, that thing can light up ANYTHING!
That last part you mentioned about being mindful of aircraft reminds me of a friend of mine who recently acquired a laser he had lost in the past once again. He sent me a video where he was pointing it around at the sky and then he pointed it straight into a passing commercial aircraft! Facepalm I was like dude do NOT do that! Not only is it illegal, but it’s very dangerous. He took it as a joke and I was like you do realize that there could be potentially 200 people on that flight, right? Now I’m not saying a laser pointer is gonna cause a plane to crash, but still… have some common decency.
nottawhackjob
He’s dam lucky he’s not getting to know Tyrone in an intimate setting. Shocked
Neurotoxin
Hey, Evil Genius, I was watching some videos on yt last night and ran into one where they reviewed a couple of Fireflies flashlights. It was a video by Matt Smith (adventuresportflashlights) from 2018. Anyway, it got me interested because he mentioned that that brand offered premium products with high performance for a modest price. So hours later, I got the curiosity to check out their website. First page that loaded contained a “featured” section of flashlights, of which I clicked on the T9R cuz it caught my eye (I’m into throwers). Anyway, the light comes in 3 different configs, 2 of which are an osram LED and the other being an SBT-90.2.
Point is the Osram emitter is the one checking out. With that LED, the flashlight produced a beam that looks like an LEP flashlight. CULNM1 10W is the LED you wanna look into. It produced 1.5km of throw at just 900 lumens, and as I said previously, the beam looks like an LEP light, so even though it’s only 900 lumens, it produces a very focused “laser” beam that’s easily visible and very long. Not that hard to drive either, I think it takes just 6amps for max output. This LED is mounted on a single 21700 flashlight so you shouldn’t have any problem with a custom build. Only downside is, the emitter seems to be quite inefficient, so output drops a bit even if not prompted to by heat management. Also seems to get hot rather quickly (flashaholic mentioned this on his YT review. Although, I doubt any of this will be a problem since you’re only gonna be blasting the lights in bursts, so it sounds like this LED fits ur application perfectly. Now I don’t know how much they cost, but I don’t think they should be too expensive.
dthrckt
dthrckt's picture
Last seen: 2 weeks 5 days ago
They were pretty successful w/ the vertical lights in this story. Probably outside the budget.
https://www.nytimes.com/2019/09/09/nyregion/911-tribute-birds.html
grin
Last seen: 3 days 17 hours ago
If you can find a 90cm mirror all you need is a 100w HID kit. All up cost about AUD$280
1km
3km
Dr scott Diabol...
Sitting on my living room floor, I’m already 4,992 ft above sea level. So yeah, in winter we do get some LOW clouds if the winds are blowing “upslope” from east to west against the mountains. Normal cloudbase for cummies (when there are any) is around 3,000 AGL. This side of Colorado is a desert, so they’re kinda scarce. But yeah… huntin’ zepplins…. that’s the goal. And yeah, it’s a felony and a Federal crime to point a laser at an aircraft. Plus, it can be dangerous. Commercial laser shows require an FAA variance. There’s a form that must be submitted, etc. Conventional searchlights are OK as long as you’re not being a douchebag and hotspotting aircraft.
Dr scott Diabol...
The Osrams max out at around 4.3 amps per Djozz’s posts. I went with a 3-amp driver from Mountain electronics b/c it was $4.60, and a 4-amp driver would have been $20.00. Likewise, the led was about $6.50. It’s not anywhere near the SBT90.2. But it doesn’t cost $130 from Mouser either. And, it’s still pretty much the king of intensity for 1mm2 dies. Enderman’s “Optafire” & “Lightcanon” are the two projects I’m emulating. My design won’t be as powerful as his. But it’ll be cheaper and that will allow me to just build more units and gang them together. I’m not looking for numbers with this project, so I don’t need a single giant emitter. And yeah, I’ve seen those videos. Every encouraging, even though I’m going with a 100mm aspheric lens (if Fasttech ever ships it).
Dr scott Diabol...
Same plan, smaller & fewer emitters.
Dr scott Diabol...
grin wrote:
If you can find a 90cm mirror all you need is a 100w HID kit. All up cost about AUD$280 1km 3km !{width:40%}https://i.imgur.com/8FeRwFA.jpg!
Oh, I can find a 90cm mirror. Phoenix Electroforms can make me a nice Rhodium-plated one. It’ll cost about $5,000 US. And if I had that kind of budget, I’s just save up a bit and get a Sperry carbon-arc and smoke all ‘da fools. The reason you don’t see reflectors bigger than 90-120mm is because holding tolerances at that size is extremely difficult. Enderman used an 11” (about 275mm) Phoenix reflector and it cost him the equivalent of a week at Disneyland. There’s a guy on Ebay selling glass parabolics up to 14.25”, supposedly made by Buffalo Precision Glass. But I can’t find any projects that have ever used one. And $280 for a possibly sketch optic is too rich for me. I know the cheeze-grade 100mm Fasttech aspheric will work b/c Enderman already proved it would. And it’s only $7.63 plus shipping (and maybe 3 months of waiting).
Neurotoxin
Where would one even start to look to find such a relic? And how much is one of those anyway? Must be worth a pretty penny.
My Nitecore TM39 just came in today. Did a bit of testing around the house/neighborhood but I really need to go somewhere else to test it properly. I will say the SBT-90.2 is one impressive piece of semiconductor. This thing easily lit up an apartment complex that’s ~400m away on low (200 lumens) and absolutely obliterated it with light in turbo, to the point where to my eyes, it all just looked washed out and all I could see was white. Ppl im that building must’ve been thinking there was a chopper looking for someone, although after a while they’d probably realize they never heard it and realized something else was going on. (There’s a chopper that patrols through this area pretty often, but I’ve never seen a searchlight on it). Can’t wait to try this out by El Morro and shine it on the side of a cruise-ship and don’t worry, I won’t aim it at any harbor pilots, lol. There’s a mountain peak close to my house where I can even see the sealine, the airport, El Morro and all of that, might go by there tomorrow night and hope it’s not full of cops like always. They just loooove killing people’s buzz up there.
grin
The buffalo glass mirrors are very good quality and the easiest way to get the effect you are looking for. The HID is cheap and doesnt need so much cooling.
Neurotoxin
!{width:40%}https://i.imgur.com/BNCm4Yz.jpg!
Is there any thread you could point me to of a how to of someone building a really high power spotlight? I don’t care about efficiency or size, I’d just love to build something that can be seen from miles and miles away and can throw a very defined beam at the clouds miles up in the air. Preferably something that’s relatively affordable to build too, under a thousand dollars and even better if it didn’t total more than $500. I just wanna obliterate the clouds and have a “batman signaler” type of beam. I’ve always wanted one of those since I was a kid.
