Fire-Foxes Flashlight FF5 11-11Special promotion,,floor price
Fire-Foxes FLASHLIGHT Aliexpress store 11-11 All products, low price promotion,
Global Express store:
https://es.aliexpress.com/item/4001256219250.html?spm=a219c.12010612.814…
FF5 Brief Description
1 Product Description
Ff5-100w hid, ignition for 100 watt lamp, 120 watt battery input power, is the current limit value of portable HID flashlight. The 100 watt luminous flux is 10000 lumens, and the measured and calculated light intensity value is 1 million CD,
2 Design
FF5 is a high and low gear design, with 100W high grade and 40W low grade. It can be changed by pressing the side switch. There is a temperature control system inside. Once the temperature control takes effect, it will automatically jump and lock at 40W;
3. Design of heat insulation ring for flashlight
FF5
It is a 100W high power flashlight. In order to ensure user comfort, this feature is added at the expense of flashlight length. The handle can isolate 20-30 ℃ from the lamp head. For a long time, the temperature in the handle only comes from heating the battery.
4. About the color temperature of the flashlight
The default value for The Flashlight is 4300k.
FF5-Battery rack version
I basic parameters
High light source flux: About 10,000 lumens
Low: 4000 lumens
Illumination Distance (ANSI) 2000M
Size Length x handle diameter x head diameter: 200×49×95mm
Approximate weight 790g (without battery)
High output power: 100W low: 42W
42w thermal protection when thermal protection is activated
Power battery rack, user can change batteries, short circuit, reverse polarity, over discharge protection
Black Friday’s discount is coming. Hurry up, my friends
