Review: SunLike 50D SOL COB E27 LED bulb (4000K) (CRI 99)
25 posts / 0 new
Taskulamppu
Taskulamppu's picture
Measurements:
  • Power consumption: 51.1W
  • Heatsink temperature after 1 hour: 71.5 Celsius
  • LED emitter surface temperature after 1 hour: 100.2 Celsius
  • Ambient temp: 23.6 Celsius
  • Dimensions: width 119mm /// height 174mm (without diffuser) /// height 230mm (with diffuser)
  • Weight: 638.6g
  • 100% flicker free
  • Easily removable diffuser (you can screw it off)
  • Lumens: 4343lm (not super accurate measurement)
Opinions:
  • Build quality is great
  • Perfect tint and color rendering (source)
  • This bulb can work with a dimmer but I don’t have one so I can’t test it
  • Immensely bright light bulb. Constant 4000 lumens is no joke.
  • This bulb would be nice for people who suffer from seasonal affective disorder. This bulb honestly boosts my focus and mood a little bit during the dark winter days here in Finland.
Overall I give this bulb a 10/10 rating.
size comparison to D4V2 flashlight
lovely double light bounce setup creates a beautiful soft lighting with this bulb. perfect!
emitters @ full power
Product page: http://sunlikelamp.com/index.php?route=product/product&path=59&product_i...
(My bulb configuration when I bought it: voltage: AC220V /// spectrum: 4000K SOL /// small diffuser: leave big one /// bigger radiator: 120mm without fan /// reflector: 50mm /// add brightness for SOL: 200% LEDs /// socket: E27)
Edited by: Taskulamppu on 11/20/2020 - 03:58
SunLike
SunLike's picture
Last seen: 3 weeks 18 hours ago
Hat
also 120mm body can be bigger
also there is 125mm body, but now it is impossible for me to find where to buy it Crying
it is more cold, lighter weight and more beauty than 120mm body
BelMORDOR’s Ламповщик|Lampman
https://t.me/sunlikenews
SunLike
SunLike's picture
thanks for review! Thumbs Up I will do some discount with your next order. Too much unfinished orders…. I need to work..
p.s. AD — Active (cooling) Dimmable, so, it is 50D (48-50 real watts when it is already hot)
pps. Reflector for 4pcs 13w leds I created by myself, just cut it from 2pcs 36mm reflectors
here was diy too
Chicken Drumstick
Wow that thing is huge. But pretty cool. Do they come in bayonet fitting?
SunLike
SunLike's picture
you mean B22?
Chicken Drumstick
you mean B22?
Yep that’s the one.
SunLike
SunLike's picture
you mean B22?
Yep that’s the one.
YES
Slim Pickens
Slim Pickens's picture
Last seen: 1 week 4 days ago
This thing is so impressive. I want one but am not sure about suitable light fixture styles. Any recommendations for fixture styles that would suit this beast?
Taskulamppu
Yea I was wondering what the “A” stands for. The title of this review has been corrected.
This bulb surely needs a big light fixture! A massive floor lamp like this might work nicely with this bulb. I recommend doing a ceiling bounce with a 50W bulb.
I don’t recommend fixtures like this unless you have a dimmer. 50W LED bulb without some kind of light diffusing solution would be unpleasant to look at.
I created my ceiling light bounce fixture from this IKEA ceiling lamp. Works perfectly in my living room:
Extra tip: there are inexpensive E27 (and other socket types) extender adapters available on Ebay and AliExpress so you can fit a large bulb like this on some fixtures that would not allow it otherwise. (like this )
Hikelite
SunLike wrote:
Hat
Well E27 light bulbs can be big, no joke.
Agro
Agro's picture
Last seen: 1 min 39 sec ago
For a while I’ve had a project on my mind to do an overkill desk lamp that would double as semi-portable light as well.
Some flexible base, a dimmer (a MUST), the biggest and baddest SunLike bulb with a 60 degree lens.
I lack time for it, but so far I mainly fail to find a really sturdy base.
SunLike
SunLike's picture
Hikelite wrote:
SunLike wrote:
Hat
I think that with E40 it will seems better Silly
SunLike
SunLike's picture
Agro wrote:
For a while I’ve had a project on my mind to do an overkill desk lamp that would double as semi-portable light as well. Some flexible base, a dimmer (a MUST), the biggest and baddest SunLike bulb with a 60 degree lens. I lack time for it, but so far I mainly fail to find a really sturdy base.
Steve
SunLike16T LED lamp:
http://sunlikelamp.com/index.php?route=product/product&path=59_64&produc...
v1.0
painted
v1.1
SunLike
SunLike's picture
$%^& chinese plastic =(
Agro
Agro's picture
That lamp is very nice. Quite far from what I’ve had on my mind (Diffuser + reflector rather than lens, not as overpowered, mounted rather than standalone) but it is still one of the most interesting lamps I’ve seen for sale.
SunLike
SunLike's picture
From different factories, even externally, plastic differs in structure, which is stronger can understand only with the passage of time.
Robin Dobbie
Last seen: 17 hours 21 sec ago
That is a sexy beast.
djozz
djozz's picture
Last seen: 10 hours 55 min ago
Nice review Taskulamppu! This sure is an impressive bulb.
@Sunlike good fortune with your small business, I love your DIY experimentation. I think that you found a niche with these high power high CRI bulbs that is not covered yet by the big manufacturers.
Agro
Agro's picture
BTW, looking after E40 bases I found an E40 bulb…
https://e40-led.eu/index.php/sample-sites/led-e40-hql-hqi-ersatz
100W, CRI95min (9698 in actual test), 11 000lm. And lens.
Even bigger overkill…aside from the fact that sometimes enough is enough, it’s only 5000K, far too cold for me.
They offer CRI85 bulbs up to 160W and just under 22 000lm.
Agro
Agro's picture
SunLike, you show several different radiators for the largest bulbs. I see how Taskulamppu has measure the bulb weight but I’m not sure if that measurement is relevant to the bulbs that you sell now.
I’d like to buy SunLike50AD with a lens and I have a few questions.
What is the weight with the passive and active radiators?
Do you have any sound pressure level measurement of the active bulb? I read that you describe it as silent but I would welcome so hard data to be able to decide whether it’s silent enough for me.
How will doubling the number of COBs affect the beam of the variant with a lens?
SunLike
SunLike's picture
50AD ⌀95mm is 435g, noise like from laptop
but it is really hard to build it (for me), so I recomend 50D with ⌀120mm
43mm lens can be used with 25w cob led or with 4pcs 6-10w cob leds
Agro
Agro's picture
Ouch. That’s not what I would call silent. So I’d rather take 50D. Is the radiator the same as the OP got? I mean – may I assume that the weight is similar?
So 40W is the maximum I can have, right? That’s enough anyway.
Will the beam have flowery petals or can the lens smooth them out?
SunLike
SunLike's picture
OP it is Topic Starter? Yes, it is 50w body
25W SAW LED can work with some overload. For example 1440mA is maximum current from datasheet, I use it with 1200mA in 50w model, but you can choose 150% or 200% of leds
also 10(12)w SAW cob led have size like 6w cob led, so I can place 4pcs under one 43mm lens, yes it is not perfect and have flowery petals near outline of beam
Agro
Agro's picture
I see…SAWS1566A is a 25W COB but can be driven up to 56.2W. Seemingly it is rated as 25W only for the sake of efficacy. About 90 lm/W at 25W and about 80 lm/W at 56.2W for 3000K. I care about the perfect beam shape so single COB is the thing for me.
It looks like SAWS1566A would be a good choice for me, though SAWS226AA looks even better with close to 100 lm/W at 50W. Wink
SunLike
SunLike's picture
Agro wrote:
I see…SAWS1566A is a 25W COB but can be driven up to 56.2W. Seemingly it is rated as 25W only for the sake of efficacy. About 90 lm/W at 25W and about 80 lm/W at 56.2W for 3000K. I care about the perfect beam shape so single COB is the thing for me. It looks like SAWS1566A would be a good choice for me, though SAWS226AA looks even better with close to 100 lm/W at 50W. Wink
Sorry, but I have no SAWS226AA and dealers too
Better I will use 4pcs 10(12)w with 18 crystals each
