Making a P60 Copper Smoothie
19 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 5 years 1 month ago
 copper1
 I'm at it again!
I'm starting to feel like it's more fun making these "from scratch" lights than modifying other production lights.
I bought a P60 Drop-in from Illumination Supply and since it's my first one ever, I had no light to put it into, so I took a piece of 1" copper pipe and waddya know? It looked like a perfect fit (almost)...
The parts in the photo are a section of 1" copper pipe, various copper fittings, the modified drop in, a McClicky switch, 6AAA battery holder (3series/2parallel), a 2.8A - 8*7135 driver and a glass UV filter.
The story is best told in the video shown below.
The LED will be an XM-L T6 and should come the first of this week. I will do some beam shots when it's finished.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 02/05/2012 - 22:43
jacktheclipper
jacktheclipper's picture
Last seen: 11 hours 40 min ago
I dig your mods .
What I do
Mr.BrightLights
Last seen: 9 years 4 weeks ago
Will it also run with a li ion? This one has my attention;)
Old-Lumens
The battery holder is 24.5mm x 110mm. The pipe is 26.2mm ID, so a 26650 would fit in the pipe, but you would have to make a spacer because of the 110mm length. Or if you made one of these lights yourself, just make it to length. The last one I did held 3 "C" NiMHs.
Chicago X
Chicago X's picture
Last seen: 8 years 6 months ago
Very nice, as always O-L.
I may have a piece of aluminum scrap that would work out perfectly as a spacer.  I'll let you know tomorrow.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
ezarc
Last seen: 2 months 6 days ago
My internet it too slow to load the video but it looks really nice.
ruffles
ruffles's picture
Last seen: 1 week 1 day ago
I'm impressed and inspired.
eg1977
Last seen: 8 years 7 months ago
Nice creation
Old-Lumens
Spacer? I am already all spaced out. Cool  No need to look for one, the light is ready to go, except awating the XML, which should come today.
Thanks anyhow.
Old-Lumens
Thanks to all, for the positive comments. Much appreciated!
Old-Lumens
Well, the light is done. Undecided   Not working as I planned, but working. It's the McClicky that seems to be acting up, or maybe it's made that way, but when I first touch the switch (just barely touch it), that's when I have to "mode change". If I just "turn it on" it doesn't mode change after it has been turned on. In other words if you just click it it's on and if you try to change modes after that.....Yell.... Oh never mind, it's just a really strange switch probably designed for some oddball light. I can't figure it out.   Too hard to describe, but I don't know why it does that. Very disconcerting...  Having to mode change by barely depressing the switch (before the click) and then when you got the mode you want, you have to continue depress completely and quickly in that moment, or it changes modes.
Well, I guess I could do something else with it, but you know? I'm done.
After a while it sinks in that (for me), what works is "Maglite & Direct Drive" or making my own simple switch, like the first copper light was.   I cannot be trying to wire all these circuit boards. It does not work and these fancy switches just don't seem to work for me either. I just like simple on/off.   Just like a flashlight used to be and that's what I'm going back to. Of course that limits me, as these cree emitters can't take direct drive nearly as well as the old "D" bin P7s did, but that's life too. A "D" bin P7 on four NiMHs direct is every bit as bright as these XML are and it doesn't fry like these XML do...    ProgressFrown...
Oh Well, life is what it is. Here's a couple of final photos of it and it's history...Tongue Out
111
I ended up using the rotary tool to grind down the reflector some, to clear the wires and sink the reflector farther down onto the pill and I made an isolator from a plastic washer, by sanding it very thin.
222
The lens is held on with a bead of epoxy between the lens and reflector.
333
beam
I have yellow (cream) colored walls in the garage. Every beam always looks funky with cream colored walls.
 Edit: The McClicky is ok, it's just a forward clicky. Modern technology will be the death of me...Tongue Out
Carry on!
JohnnyMac
JohnnyMac's picture
Last seen: 1 day 2 hours ago
Carry on!
LOL!  I read the first paragraph in the last post and was wondering how long it would take you to realize your switch was fine...just back asswards.  I personally don't like forward clicky switches either. Wink
Nice work on the light.  It looks great!
dthrckt
dthrckt's picture
Last seen: 3 days 7 hours ago
nice job.
i think i'm starting to agree w/ the DD stuff, too...
so, have you already made a similar light w/ a step up converter on the end to use a larger reflector?
seems like a great way to build a fixed aspheric
atbglenn
atbglenn's picture
Last seen: 2 years 6 months ago
Old-Lumens, very impressive as usual.
Boycott Nike
Chicago X
Chicago X's picture
Great Job, O-L !!!
The light looks awesome.
BetweenRides
BetweenRides's picture
Last seen: 3 years 5 months ago
Beautiful light, Old-Lumens - when you going to put it up for sale?  Laughing
I dislike forward clicky too.  First light I had with it I thought it was broken.
Old-Lumens
dthrckt wrote:
nice job.
http://budgetlightforum.com/node/6818
I think that's the one you were thinking of. Still in the works. Now I'm probably putting an SST-90 in it and "it" will be a 3D instead of the 2D, with the adapted head.
Old-Lumens
Actually this one was spoken for before I ever got the light finished. Those copper lights may be in demand as they get known better.
I'm going to do another one soon and it will be unique (again)...Wink
Old-Lumens
Thanks everyone for the comments.
I love the fact that a P60 drop-in can have such a nice beam with an XML in it.
