Need advise to repair a plasma ball - C2073
23 posts / 0 new
patmurris
patmurris's picture
Last seen: 1 week 6 days ago
Hi all! Smile
Over the last few years i bought a few plasma balls on AE… and most failed after a while. The last two only worked a few hours…
When looking inside, i notice a burnt smell and brown traces around a component that looks like a FET onto which is written C2073.
I plan to order and replace that component to see if it fixes the problem, but i have doubts about the voltage it can deal with. Over here the AC runs around 240V and it seems this transistor is only designed for 150V – not sure about that though, and maybe the voltage is lower at that stage in the circuit?
What do you think?
Is there a higher voltage equivalent for that component?
Thank you for any advise.
Edited by: patmurris on 01/03/2021 - 10:24
sp5it
sp5it's picture
Last seen: 6 hours 37 min ago
C2073 is NPN silicon transistor.
Depends on it’s place in circuit 150V may be enough.
Mike
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
 If a lot of people listen to Slayer, the world would be a better place to live" - Tommy Wiseau
patmurris
patmurris's picture
One thing i’m thinking about is adding some sort of heat sink to the transistor…
Talkrabb
Talkrabb's picture
Last seen: 15 hours 32 min ago
The fat U-shaped black line on the PCB around the transitory indicates here should be a heat sink from the beginning.
My current favourite: Fireflies E07 V2, XPL Hi V2 5A 4000K Neutral White, Matte Black
patmurris
patmurris's picture
That explains the fail after a few straight hours working…
Shame on the manufacturers cutting such corners.
Lightbringer
Lightbringer's picture
Last seen: 19 min 10 sec ago
I’m shocked… shocked… I tell you!
RobertB
RobertB's picture
Last seen: 7 hours 46 min ago
icpart
Last seen: 8 hours 5 min ago
Also from picture of PCB under transistor you can see that seems transistor has been overheated.
snakebite
snakebite's picture
Last seen: 2 days 8 hours ago
would you believe that the stamped heatsink now costs more to make than the high voltage power transistor that is supposed to be attached to it?
only way this kind of crap manufacturing can work is to get the contract by sending out golden samples and the bulk shipment is “cost reduced” aka cheapened.
mfr got paid,junk is being shipped on a junk,and mfr closes shop reopening under a different name and maildrop.
btw if you get a heatsink on that transistor your next failure is leakage of the globe.
those cheapies usually dont last.
the gas mixture/pressure is critical.
kennybobby
kennybobby's picture
Last seen: 2 hours 13 min ago
Was there a transformer or other board in that unit—where does the AC come in and where does it go?
Where do the pink and green wires run to/from?
Was that black wire from the big black cube broken or exposed when you opened it up? That needs to be well insulated as it is the HV output of a coil such as to fire spark plugs in a car.
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
patmurris
patmurris's picture
The pink and green wires are the AC and they go straight into the PCB, no transformer.
The black exposed wire is the output of the HV transformer (the black cube). It’s insulation melted because the overheating transistor was bent forward and was touching that wire, that then goes up into the glass globe.
I managed to salvage that one by replacing the transistor and adding a small heat sink. I also insulated the exposed part of the HV black wire. However i failed to resurrect a second unit… Either my soldering was really crappy or there is another dead component in there.
One out of two repaired. Not so bad.
kennybobby
Were there any ic’s on the board? What about a diode bridge rectifier? Can’t really see what’s on the board to know how it is controlled.
patmurris
patmurris's picture
I don’t think there is any IC or rectifier in there but i may be wrong. For what i’ve seen it’s a very very simple design. A few capacitors and resistors, the transistor, the transformer and that’s it.
Lightbringer
Yeh, those are just simple HV supplies with maybe some tweaking of the voltage to get different effects.
Brunola
I have a burned resistor on this same circuit. I’ve just send you a PM Patmurris in case you can tell me which was the ohms value of it so I can replace it.
Pic:
https://ibb.co/DRx8Gs5
kennybobby
Howdy and welcome to the forum Brunola
Have you traced out this circuit and could draw a schematic? Or post a good picture of the top and bottom sides and somebody here could do it.
What is the little 4-pin chip with the white line in the upper left of your photo—is it a diode bridge rectifier chip, can you read the part number on the chip?
Is the surface of the globe connected to anything, such as to the earth ground terminal of the AC plug?
Brunola
Thanks Kennybobby!
Sorry, no schematic… I’m an electronic newbie and was just looking to replace the burned resistor, as it was obviously burned, to repair the plasma ball. And i found this thread where patmurris has the exact same circuit!
Here’s some pictures:
https://ibb.co/bX7VDkq
https://ibb.co/QvLV15K
And here is a closer picture of the little chip you says: https://ibb.co/qxJpycj
No grounding for the surface of the globe…
kennybobby
Thank you Brunola for the great pictures. Indeed that is a mini bridge rectifier rated 0.5Amps and 1000V peak reverse.
MB10M datasheet
Let us know if you hear back from Pat with the resistor value.
patmurris
patmurris's picture
@Brunola; sorry for the late reply, i was quite busy… and out of my house for the summer so i don’t have access to any plasma ball pcb at the moment. I checked whatever picture i took at the time but can’t seem to find anything that could help with this resistor value.
BTW: the one i thought i did fix apparently failed again very quickly… It was return to me after a while and is still waiting some more fixing.
Not sure this is worth the trouble, but i’d like to be able to make those plasma ball work because… well, i like them. That’s gonna take some more time i’m afraid.
kennybobby
This is a really cheap power supply and somewhat dangerous with no fuse or circuit protection.
From what i could calculate you could use a 1/4Watt resistor of 33 Ohms in R3. This is assuming a 240vac mains voltage and 340VDC for the DC buss.
This would put about 2.5 V at the base of the 2073 transistor, which is half of its max base voltage rating. With a base current of 50mA the collector current would be 0.5A. The 2073 is rated for 150VDC operation and 1.5A max.
i couldn’t find anything about the CF transformer.
The plasma discharges in the reduced pressure gas (partial vacuum) in the globe, then the electrons pass thru the air to return to ground, or thru your hand to charge up your body if you touch the globe. Enjoy! Smile
Brunola
Thanks Patmurris for your answer and thanks kennybobby for the hard work!
I’m now out for holidays but will for sure make the repair when i’m back and let you know!
Have a good one!
kennybobby
@Brunola, when you get back from holiday can you measure the resistance between the 4 terminals of the CF transformer as described below before you install R3?
Also can you read the values and voltage ratings of C3, C4, C5 and C6
At first i was thinking this might be using some sort of LC feedback such as in a Hartley oscillator circuit, but now it looks like a flyback transformer with Primary and Auxillary windings.
i’m guessing that CF3 to CF4 will show a resistance value as the Primary winding.
And CF1 to CF2 will also measure a resistance as an Auxillary winding.
And there will be no continuity or resistance reading between these two winding, open circuit
e.g. CF1 or 2, to CF3 or 4
[edit]
i was able to put together this simulation and get it to oscillate at about 440 Hz, but the values were just guesses and adjusted as necessary to get oscillation, hence the need to get some true values of what is on the board if possible.
hank
hank's picture
Last seen: 8 hours 19 min ago
Yet another reminder that when you buy anything electrical cheap-from-China, the first step you should take is always to take the cover off and look for cheap and/or dangerous design/build issues.
