14500 selection
6 posts / 0 new
buck91
buck91's picture
Last seen: 9 min 20 sec ago
14500 selection
Is there any 14500 cells out there that have a build-in charger and can be charged on a typical li-ion charger?
MascaratumB
MascaratumB's picture
Last seen: 2 hours 18 min ago
I have 1 Wuben cell that as Micro USB built-in charging and it charges without issues on a normal charger.
Also 1 Lumintop cell that does the same thing too Wink
flydiver
Last seen: 10 hours 56 min ago
Confirm the Lumitop will charge via USB or suitable conventional charger.
To Air is Human, to Respire….Divine.
Lightbringer
Lightbringer's picture
Last seen: 5 hours 53 min ago
Most do, but most are also quite a bit longer. My Wuben 14500 doesn’t fit any other lights I tried it in.
amtaham
amtaham's picture
Last seen: 12 hours 32 min ago
“Come again, please, come again, Whoever you are. Religious, infidel, heretic or pagan. Even if you promised a hundred times, And, a hundred times you broke your promise, This door is not the door of hopelessness and frustration. This door is open for everybody. Come, come as you are.” ~ Mawlana Jalaludin Rumi
Ventsi
Last seen: 4 days 15 hours ago
Klarus also has 800mAh that fits the criteria. I believe it’s the Sanyo UR inside.
