Test/review of Vapcell INR18650 3000mAh S30 (Red) 2020
9 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 18 min ago
DSC_3979
Official specifications:
  • Nominal Capacity: 3000mAh
  • Min Capacity: 2900mAH
  • Nominal Voltage: 3.6V
  • Discharge End Voltage: 2.5V
  • Standard Charging Current: 2A
  • Charging Voltage: 4.20 +/-0.05V
  • Max. Continuous Discharging Current (Vapcell specification): 25A
  • Dimensions: 65.00mm (L) x 18.3 mm (D)
  • Weight: 50.0g max
Vapcell%20INR18650%203000mAh%20S30%20(Red)%202020-info
This is a fairly high current 18650 cell from Vapcellwith good capacity.
DSC_3974 DSC_3975
DSC_3980 DSC_3981
DSC_3976
DSC_3977
Vapcell%20INR18650%203000mAh%20S30%20(Red)%202020-Capacity
The two cells tracks nicely and hold voltage fairly well.
Vapcell%20INR18650%203000mAh%20S30%20(Red)%202020-Temp-15.0
Vapcell%20INR18650%203000mAh%20S30%20(Red)%202020-Temp-20.0
Vapcell%20INR18650%203000mAh%20S30%20(Red)%202020-Temp-30.0
Vapcell%20INR18650%203000mAh%20S30%20(Red)%202020-CapacityTimeHours
Vapcell%20INR18650%203000mAh%20S30%20(Red)%202020-Energy
Vapcell%20INR18650%203000mAh%20S30%20(Red)%202020-PowerLoadTime
Vapcell%20INR18650%203000mAh%20S30%20(Red)%202020-TripCurrent
Vapcell%20INR18650%203000mAh%20S30%20(Red)%202020-Charge
Discharge-Vapcell-S30-18650-pulse-1.0%2010%2010-IR
Conclusion
This is a fairly good cell with both capacity and high current.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Edited by: HKJ on 01/11/2021 - 10:55
Cochise334ever
Cochise334ever's picture
Last seen: 57 min 46 sec ago
Thanks for the review and all your valuable work.
You mention in the First line that this is a KeepPower cell? Must br a Typo.
Most cells seem to have over rated capacity.This being 2800mAh instead of claimed 3000mAh is a bit more over rated…maybe a VTC5D rewrap?
To admit is to acknowledge.To Accept is to take action.
HKJ
HKJ's picture
It is and I have corrected it (At the current time I am doing a lot of Keeppower cells).
The typical cell rating requires a specific temperature for charge and discharge and charge may be with a lower termination current than I use and is usually also to a lower voltage than I do. All this together can explain some difference.
It may be a rewrap or a Chinese cell, some China factories are getting very good at making LiIon batteries.
vapcell Dennis
vapcell Dennis's picture
Last seen: 4 days 7 hours ago
It hasn’t discharged to 2.5V
The battery capacity is about 2950mah
This is not vtc5d
vapcell Dennis
Thanks HKJ Thumbs Up
Sunnysunsun
Sunnysunsun's picture
Last seen: 47 min 15 sec ago
Can you tell us the battery inside? It seems to perform slightly better than the VTC6 at 15-20 amps but is just a little lower in capacity.
vapcell Dennis
Custom battery, we should be the only one with this battery at present Smile
Th558
Th558's picture
Last seen: 7 hours 13 min ago
This would be great for high power soda can lights.
Barkuti
Barkuti's picture
Last seen: 1 hour 17 min ago
This is a discharge rate enhanced Samsung 30Q; the shape of the discharge curves match, its top too. Versus a 30Q its internal resistance is lower, while its capacity is a little bit lower. This allows the cell to meet a 20A continuous discharge rating without exceeding 80°C (at 25°C ambient).
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
