Does anybody make a headlamp with a UI similar to Zebralight/Armytek/Anduril that also has built in USB3.0 charging (and at least 85cri)? I love my AT Wizard Pro Warm XHP50 but it takes a unique charging cord and I would love to slim down the travel kit if possible.
USB 3.0 isn’t a charging standard, what do you mean by that?
Idk about usb3.0, but the astrolux headlamp has usb-c charging, anduril, and good cri options abd is around $30 on group buy codes here on blf.
The lumintop hl3a is amazing, with high cri and 3 leds so high output, anduril, and may have charging but I don’t know , but is also hard to find on sale… more like $50 for that one. I’m sure there’s others though as many like skilhunt and sofirn make an array of headlamps too
Headlamp is wearable equipment- tool , its more logical to have spare battery.
Usb port is more of the interface which a PC interacts with a device like a portable hard drive or a usb drive, So technically they are not a charging standard though how much power it can provide is different it also depends on the quality of the cable its also vastly slower than using a generic brick you would plug a usb cable into thats powered by all socket.
Whoops, typo on the 3.0. Yes, I meant USB-C! I’ll check out that Astrolux.
If you don’t mind the extra bulk of the 21700 form factor the Wurkkos HD20 is quite nice with a XPL spot and a High CRI 5000K LH351D flood beam. Has usb-c charging and also works as a powerbank with a usb-c to usb-c cable. Charges my Pixel 2 and tablet fine at 2A but for some reason it won’t charge my Unihertz atom xl though.
